Stock width g1 raptor
I originally installed some extended brake lines on the front but I kept having issues with them being toooo long so I went back to my old +2 front lines and installed a drop bracket.
I have an alinement schedule at ORW Tuesday but looks like I need to take some turns out of the uppers... I got aggressive with the rod ends to help with spring clearance but looks like I need to get that camber under control
Look at SPC 86252 for the lower control arm cams. The 86250s werent cutting it for me.
Nice! Im hoping they also help my LCA bushings last longer too. Were your “blocks” spinning before you welded them?
They did tilt slightly they have a dowl to hold them in place but I wanted it more solid it just seemed like a good idea at the time tbh.
Working on my AUX fuel tank mount while im trying to fix my rear shocks ,
I was short a bunch of hardware but the front support is coming along, it will bolted to my "modular" resivor mounts using the tanks nut inserts and a 1" ratchet strap will lock it in for the front:
This is the idea: no rear mount yet, so dont worry about the tilt
