2003 Tacoma Steering Rack mount and “rack guide”
Dirt Yota
Camarillo
Wasn’t sure what section for this so figured suspension and steering go together, enough.
Stuffed it a while back pretty good on passenger side, rack appeared to skip some teeth internally and was ready to be swapped.
Took old rack out, went to put new OEM rack in with a fancy billet rack mount…
-2003 Tacoma
-bent rack mount and stud
-passenger side upper stud/bolt for D bushing
Try to remove and hope nut isn’t fubar and I can get a new one in or hammer that shit straight and send it?
Just before pulling old rack
Upper stud very happy to see me
333 Fab billet bracket told something ain’t lining up
Stock bracket/mount lines up haha
Any suggestion or past experience and tips for this one 🫠
I’d try using heat(MAPP gas or smoke saw—oxy acetylene), get the area around the studs red hot and try to bend them back to stock~ish location. After that invariably DOESN’T work, cut the entire face of the stud plate off and make a new one.
Cut here and replace with a beefier plate with nuts welded to the back side.
Use the rack to tack that motherfucker in place, verify everything is level, cycle the suspension with the coilovers removed, and once you’re sure it’s location is legit, burn that fucker on.
Ugh I run a zip tie/duct tape only shop here… we don’t do fab work in this garage 🤡 hoping a lil heat and a pipe will do the trick! 🤞
It’s straight but…
nut is no longer attached
Slid a small piece of pipe on tweaked stud, applied light pressure as tester for feel and fucker popped off! Didn’t get to use torch.
So I guess fab work is required! As I figured it would be.
Trucks funds are low as it is apparently not a family priority (even though 2.5 out of 4 think it is) but I’ll update with pics once sorted out.
Open for ideas, suggestions like Turboyota gave above if anyone has some or has done this already.
Scalp this fucker and thru bolt it.
I replied before reading the rest of the replies.
Definitely do this. Sawzall will make quick work of it (use the Diablo metal blades. Milwaukee torch blades are garbage). Then use a drill next size up to get rid of those threads, put a bolt from outside in, use a box end wrench to hold the nut inside the cavity (lol), tighten away. When you’re done, cut it all off and TTB swap
Chopped it off, lil awkward angle but got it done. So I went ahead and ordered a stick bracket clamp mount dealio since the stock mount is still deformed slightly. I heated it and pounded as flat as I could. You can see in a few of the pictures how it’s not flat, didn’t tighten down bullet mount due to that. Once stock mount gets here I’ll mount rack so it will drivable to get some fab work done to replace mount.
I'd try what turboyota suggested, should be fairly straightforward.
If thats not "it", I think Tommy makes some kind of badass wazoo swing set steering for this platform?
Yes I make a few upgrades for the steering on the 1st gen taco/3rd gen 4 runner.
From a simple rack slider to help keep rack from flexing back/up/down and cracking.
https://www.tt-motorsports.com/prod...a-tacoma-96-02-4runner-rack-and-pinion-slider
To a full kill rack eliminator kit, BUT that requires a lot of welding, AND i've never done one on a stock motor truck. It looking like it should fit but I've never done that so cannot confirm. AKA not a simple NO fab tool part sale. Also it's at 5500 with box, ram, steering gear transfer etc.
20250319_171336.jpg20250806_185055.jpg1000026513.jpg1000027113.jpg1000027115.jpg1000027116.jpg
Had a window of time open up today and got the new OEM rack in fluid topped off. Wouldn’t you know it the rack has play in it! More than the old beat up rack!!! WTF!!
Is there something I’m missing when doing a basic rack swap/install? Turned it lock to lock, let it sit at each side for a bit. Checked fluid repeatedly and top off as needed 🤦‍♂️🤷‍♂️
I hate trucks! It’s always a step forward and a few back!!!
Any suggestion or ideas? I assume it’s the rack but… pretty bummed I spent the extra money for a new OEM non remanufactured rack. 😩
