Thicks91
- Jan 9, 2023
Limit strap tabs and then brake caliper tabs. I was lucky enough that a family friend that works at IMS hooked me up with the I beam out of the rem rack. There is a bunch of different ways to do it. After pre loading it a 1/8” per side down and welding 3” per side jumping around. Had to check the ratchet straps because they were stretching with the heat. It still has a 16th of preload in the axel after all said and done.
