marcytech
- Apr 6, 2022
yeah i owe ya for this one!You’re welcome
I have the hf roller and it always seems to twist the material. So it kind of spirals. I’ve tried making sure the tigers are all in line with different spacers. Not sure what it is. I beefed it up with my own swag style wings
Seen dialeds post his on bandsaw setup and thought I’d throw this out there. Portable band saw stand from harbor freight. I haven’t used one yet but planning to pick one up. Also harbor freight carries their own version of foot pedal switches, they have on/off and momentary versions. View attachment 12204
1. JD2 model 3any recommendation for a tubing bender doesn't have to fancy just has to get the job done
Was about to pull the trigger on this for my band saw but picked up a the large HF 14" wood cutting saw on craigslist for $100
I plan on doing a gear reduction similar to this guy.
1. JD2 model 3
2. Whatever the hell vertical unit @the bodj has
Peruse Craigslist and marketplace for bender/die package deals or buy the same bender as your friends so you can all buy different dies and share as required.
Thanks for that bandsaw video. I have a wood cutting saw that I’ve been wanting to convert but had no real idea of how to do it. As well as cheaply.
Mine is based on an Affordable Tube bender. Worked fine for mild steel. DOM wrecked it so I rebuilt my own out of 3/8" plate and it worked ok. I bought plate to make my own JD2 style that I'll be running vertically still.
I really like the ESAB one has white and amber lenses that are super easy to swapIn need of a new welding helmet...
looking for some suggestions
I have the same bender. I've had great luck bending mostly 1.75" DOM.
I did crack a die recently but after building over a hundred bumpers and multiple roll cages I can't be mad lol
Built a rolling cart out of some scrap and added a 12ton air over hydro ram from HF.
I'll post pics later.
Yeah let's see yours. My angles are just off with where the tabs mount for the dies, so it causes the tabs to bend. I have a 20 ton air over hydro ram on it lol.
i've got the Irwin SAE set from lowes for a couple years now. case is small and fits in the toolbox nicely but the handles do suck ass. I think ive used a socket ratchet to avoid the T-handle a couple times. better than the craftsman "full set" we have at our shop. im happy with the irwin set for now, shouldve just gotten the metric set at the time, needed it a few times since thenDoes anyone have a good recommendation on a tap-and-die set?
I have a cheap one, and not happy with it.
1. every time I open it, looks like a bomb went off.
2. the tool holders, don't hold the taps, everything is loose so it sucks to use and tap something.
I have always had Fibre-Metal hoods, had a Futura XXL for a long time that I loved but it died so I got a fiberglass fibre-metal hood and a Sellstrom auto darkening insert. Love it.In need of a new welding helmet...
i really dont use taps and dies often, but i have needed them a few times lately and every single time i have to resist the urge to trash themm. I have welded nuts on 2 of them so they are easier to use, but i am so frustrated i am at the point i want to spend the money... and likely never need them ever again. lmaoBuy good holders from starret or similar, a decent set from irwin or gear wrench, then really high quality ones for the taps you use often or will scrap an expensive part if it breaks.
