UR_Mawm69
Yeah, pretty sure somewhere or someone said I can go to 5.88s in this 8.8?Definitely needs lower gears. You can go 5.13 with the 8.8 or manual up and swap in a 9in with 6.0 gears.
Can anyone confirm?
I would find a shop to do the gear install for you and than tell them you need 6.14 ratio. If they say they can't get them show them those and see if they say they'll work.
6.14 would be old Yukon set that has been discontinued and not available through any big distributor that I could find. If that Ebay set is new than is should be good.
5.71 is still made by Motive. In fact I just ordered some this past weekend.
https://shop.advanceautoparts.com/p...-f888571/20640539-p?c3ch=PLA&c3nid=20640539-P
My local installer for gears if you bring them the axle is $300 for 9in and 14 bolt which are easiest to setup. For Dana axle and this would be $350
