Tonight I realized I never cycled everything with the bed on the truck. So tomorrow i'm going to remove coilovers and 1 spring, then reassemble that onto truck along with the bed and rear tires, then cycle checking for clearance on everything. I may have to trim the underbed support ribs since they sit directly ontop of the frame and the shock may come into contact of that but a simple notch of that would fix that issue. I will also check tire clearance and do new rear bedside support as well since it mounts to be near the frame where the cantilever arm and everything swings.
