Trailer Park Pro-Lite
I honestly prefer that over any raptor clip. Now make one where the ford ranger is converted to an obs ford front end like that.
I’d render it myself, but I am afraid of Skynet.
Blast some acetone in there to clean the schmoo out then get some cabosil fumed silica and resin mixed to the consistency of peanut butter or some gflex and stick the nozzle in and fill that crack up until it squirts out. Then tape the face up with some wax paper to keep the ooze to a minimum and let it cure for like 24 hrs and send it.
Beam is straightened! And plated!
And the sliders on the coilovers are swapped out... But now
Look at this fuckery
The piece of plate I boogger welded on cracked
New bend and crack on the top of the frame.
2 new cracks in the bottom of the frame
And it's kinda hard to see but the driver side upper link mount is pushed forward about 1/4 inch.
And the rear end is leaking from around the 3rd member at the housing.
Probably take it apart some time during the week or next weekend and give an update.
So I don't need to cut the hood and lay mat in there with resin?
Where do I get g flex or carbisol fumed silica? Am I basically just gluing it back together at that point? That sounds like a way faster / easier fix than doing a bunch of fiberglass repair.
Gflex is made by west systems, its basically like flexible toothpaste epoxy. I don't remember where I bought it.
I use us composites for most of my supplies. https://www.uscomposites.com/fillers.html
Grab some of their epoxy, the mixing pumps, the cabosil, and either some big syringes or you can make piping bags out of thick freezer bags. If you use the cabosil, make sure you wear respiratory protection, the shit floats like nothing else I have ever seen. Its wild.
Mix the resin first, and add some cabosil a little bit at a time to pet it blend properly and keep it from getting dry lumps, you want it roughly peanut butter consistency. I use like 4oz batches for the resin so it doesn't kick too quickly in the cup.
I don't have my hands on your hood so I can't say for sure but I would try filling the gap between the outer and inner liner and outer skin in a few spots and slazing up the crack in the front. To fill the gap, drill a hole in the inner liner, and spooge a bunch of the thickened epoxy into the hole with your syringe or piping bag so it spreads out in the gap. Then let it kick.
Then see what it feels like, of its still all wet lasagna noodle, sorry brah, gotta cut it open and reinforce it.
This stuff?
I'll look up that other resin stuff also
You can also add the cabosil powder to that to thicken it up a bit. Gflex is nice for stuff that needs to have a little give but still stick well.
Just make sure you get the surfaces good and clean. Use lots of acetone.
If it is doing it around the hood pins, take the flanges out and spooge a bunch of that in the area around the pin holes. Then redrill it and it should stiffen it up a lot. The goal is to make sure the inner and outer layers share the load.
With changes in my schedule and all the extra work we've got I'll have some extra dollars. But I won't be able to make it to any events until the fall. And gas prices are almost as retarded as the the cause. Anyway, I think it's time to cut the equal length 2wd front end off and swap to 4wd.
How she sits meow
I've had all the parts sitting in the shed to swap her for years
F-150 4wd beams
Trans
4wd unit
What I need to know is how far down from the frame the beam pivots sit.
And how far from bolt hole to bolt hole there are apart.
I'm gonna fab the pivots, radius arms, mounts, and cross member myself. Hopefully I can still retain the upper shock mounts on the cage
Stock pivots are roughly 7" offset center to center or 9" from front mount to rear of back mount ala crossmember inside width.
I have a junkyard with like 25 ttb trucks if you need photos or measurements I am happy to help
I'll probably start disassemble it Sunday. It's a 2wd frame and they say the crossmember on these are more narrow than the 4wd. so It may need a good bit trimmed out.
Then maybe make a tube that goes from frame rail to frame rail to hang the beam pivots off? Then plate the tube to the crossmember?
Might need to take you up on measurements from a stock 4wd frame
Yeah 2wd and 4x4 ranger frame and crossmembers are different. Fullsize they're the same beam pivots and everything for 2wd and 4x4. Clearance is only a grinder/swazall away easy when it's caged and just want it to all fit
