TheMoneyPit
Up next is rear shock mounting. Once I knock that out, the truck will finally be a roller.
Verified clearance at full droop and then started throwing together the driver's side upper shock mount. Sides/internal gusseting is 3/16" plate, while top/bottom plates will be 1/8".
With the mounts in place, rear travel is 26" metal to metal. Just need to finish gusseting/boxing, add a tube or two down to the frame for vertical strength, and then replicate on the other side.
Finished the internal gusseting and the topside plating. Hard to get a crisp line on those bent plates with nothing but a BFH, a crescent wrench, and a vise. Need to pick up one of those press brake kits for my hydraulic press.
Up next is fully welding the exterior of the mount, popping it off of the truck, welding the interior, and then plating in the bottom. Then it can get welded back on the truck for good, and tubes down to the frame can finish it off.
Finished up the passenger rear shock mount and added the cross-tube between the two. Even with templates and identical components, it took a ton of tweaking to get both sides symmetrical.
I was going to just add some taco gussets to the cross-tube, but I think I'll continue a tube like shown in yellow that matches the angle of the tire carrier structure. Then likely add some dimpled plates in the triangular void.
