TheMoneyPit
In keeping with the theme of the build, the bumper is equal parts ghetto fab yet also overcomplicated. All out of virgin .120 wall tubing, so I'm re-using tubing from the OG bumper where I can. Upper hoop bits re-bent and spliced together. Don't mind the gap. I'll slip a filler piece in there before finish welding.
Wasted a bunch of time making tabs I should just buy online.
Like the rest of the bumper, the frame mounts and center cross-tube are made up of scavenged 1.75" .120 wall tubing. Frame end caps are threaded and the bumper is attached with 4x 1/2" bolts in the middle, 2x 9/16" bolts at the bottom, and tubing connectors up top.
To-dos:
Finish encasing/wrapping the middle bumper mounts, notch 2x lower diagonals, bend+notch two upper tubes.
To-dos:
