July 28, 2019
Materials: 5/16” 4130 plate, 1/4” template plywood
Tools: bandsaw, 4.5 grinder, 1” drum sander, drill press, tig welder, large tap wrench, 3/4-16 tap
Tig welding for 3 hours in a tanktop: check
UV burns on my chest and arms: check
Should I fucking know better? Yes
Temperature in my uninsulated shop: 96F
Beers? Oh hell yes.
Finished the upper arms. When I pounded those ears down to wrap onto the tubes they both cracked at the bend. Fuckin’ weird—especially because it was obviously really hot from welding. I have no idea what material it was—it was a random piece of 3/4x1/8” bar that was sitting around. It welded fine though...
Full closeout above the spindle uniball and below what will be bump strike area. Having a c-section there worries me.
Filled the voids where the hex bungs fit into the square tube. I don’t totally hate it.
Front wrap on the other arm:
You can see where I ground out and welded the cracks in the front wrap:
Only had to run a 3/4-16 tap through one of the bungs after welding:
Speedway Engineering makes some pretty badass rotor hats. They can be flipped front to back and the rotors can be mounted on either side and flipped over resulting in a grand total of 8 different offsets from the hub face. Here are three combos:
Settled on an offset that cleared the inside of the rim, the brake line fitting and the lower control arm at full steer.
Made a lil template out of wood:
Copied that little gem onto 5/16” 4130 chromo plate:
Tig tacked them together, drilled 25/64” through and tried to rigid tap 7/16-20 on my drill press. It doesn’t get very far in there...
Used a countersink to add a nice chamfer to the holes:
Oh yeah
