Pissnoma
What trans cooler did you do just a cheapy from Napa?
Iused a Derale from Etrailer.com, its mid grade, 12"x9" I kept the OEM cooler through the trans also, Im undecided if that was a good idea or not. I would be curious to know what anyone's insight is on whether I should take the OEM through the radiator cooler out of the loop or not with the external cooler in place now.
Made some progress. The most prograss has been made making more oil stains on Turbros unstained shop floor. Unfortunately getting the correct front pitman arm proved more difficult than anticipated. So I'm kinda stuck making progress til the wagoneer pitman arm arrives. In the meantime I'm doing the SYE on the front output 233C TC and converting the TC to manual shift. If I finish that and still don't have the pitman arm I will start on the back.
I had to reposition the jack stands because the frame sag was so bad it affected the cab and made the doors hard to close. The frames on these trucks are kind of pathetic. Note the bed gap in the first pictures i posted vs the ones below. 20241217_135128.webp20241217_144114.webp20241219_131840.webp
I have an astrovan gear box if that helps, Kelly. Not sure where you are trying to get the pitman arm ti end up
