That's the goal! Hahahaha, but if I put a hot chick in there my wife would kill me LOLthis must be like one of those picture/memes they put a hot chick in... and all you can see is a hot chick and nothing else in the photo.... because all I see is beer. haha
Thanks Dude! It should be making an appearance here soon!Can’t wait to see this thing running around Michigan!
Right on man I will be at slsd and dirt fest in July but my bronco is still a ways from being ready lolThanks Dude! It should be making an appearance here soon!![]()
Ah cool! I’ll see ya around there! I’ve got a lot of work to get through stillRight on man I will be at slsd and dirt fest in July but my bronco is still a ways from being ready lol
Just a thought... Since the exhaust is right there would it help at all to double panel it? Meaning the panel you put on there is on one side of the the tube... If you did a panel on the opposite side would that insulate from the heat much?Still out here paneling in stuff. First side is taking a little bit of time to make sure I’ve got a good understanding of how everything will seal up. Still learning with a beadroller so it’s not perfect but, we’re getting there. View attachment 24459
That's my exact thought also. The plan is to wrap the headers/exhaust, then headshield the outside wall of the panel and do another panel inside with lizardskin sound deadener and lizardskin ceramic heat insulation on the inside panel so the firewall will be double paneled. Hoping the combination of all 3 will make it to where you don't even notice it.Just a thought... Since the exhaust is right there would it help at all to double panel it? Meaning the panel you put on there is on one side of the the tube... If you did a panel on the opposite side would that insulate from the heat much?
Thanks dude! I'm hoping all the thinking is on the one side and then I can just flip and repeat and the other side will go much faster. Trying to avoid as much welding as I can, so I'm trying to do the largest single pieces I can.Looks great man! Sealing up a cab when you are this deep is a lot of work, I feel your pain!
Thanks dude, probably going to add one more cross tube at the bottom of the FORD letters and connect the lower light tube to the middle with some 1/2" to give it a little more rigiditygrille tube work design is nice and clean.
If I remember right it was around 18kWhat did the bulkhead complete assembly cost?
