When you weld up all the plating and truss do you leave the 3rd bolted up in place to keep the sealing surface and beam from distorting?You can widen the passenger side this way because the axle can float around in many directions. I always setup the 3rd, up right. wider axle and stub and make sure the snout can slide over it and steer before you weld anything! You don't know how many people have cut their beams apart to get it to align after they have welded everything and been screwed!
