Pictafiedesign
- Jul 11, 2023
Landed is landed whether it's half off the frame or not LMFAO
Brake Clean is acetone in a spray bottle.
Fuckme.Eh, soak a rag in the brake clean and let it sit on or vigorously wipe the spot you want it to clean the paint off of. The reason I like acetone is it’s cheaper but same deal anyway. The solvent needs time to reactivate the paint in order to make it soft and easy to remove. Brake clean evaporates so fast it doesn’t have time to really soften the paint.
Make sure you wear nitrile gloves or your skin will get all cracked around your fingernails if you’re anything like (or as old ~40 as) me.
Awesome! Thank you so much man!69 seconds - it really depends on the paint too.
Home Depot spray paint will wipe right up and scratch off with acetone rags / scotchbrite.
Factory paint on my Toyota takes a bit more exposure to the brake clean / acetone etc. Sandpaper can be your friend too, but scotchbrite can be formed into smaller tighter areas.
Trial and error will give a better idea of how this stuff works on your truck the fastest based on what is on the frame.
Try to keep the stuff from going up your nose too - it can be harmful / give you a headache if inhaled for different timeframes for different people.
Fuck yes. Thank you so much man.Yeah factory paint (if that’s what you’re removing) takes a lot of effort if you’re trying to get it 100% off. I usually cram an angle grinder wire wheel / flap disk / dremel grinding bit or sand barrel as far in every spot as much as I can and only then do I bust out the acetone / rag / sand paper / and scotchbrite for where all of those don’t fit. Putting a decently saturated part of a rag on the paint and wiping it over and over until the paint starts to transfer onto the rag and switching over ti scotchbrite is what I usually do for those tiny last places.
This is only my method for welding prep and I’ll only remove as far away as I need to from the weld site so that I won’t get any funkiness from inclusions and stuff. If you’re just cleaning the frame for repaint then just degrease it, give it a scuff with sand paper or scotchbrite and wipe it down with acetone and you’re good to paint over whatever is there if it’s not flaking or rusted. No need to remove all the factory paint unless you’re welding on it or something.
