Babe,I'll definitely be hitting dirt with it before I ever sell it. I just need to see how finances work out. Hard to justify to the wife having three trucks haha
If I ever need to take the plenum off I’ll add flanges or couplers at that point.
Hope that's not needed mid-trip. I've had to replace a fuel injector seal once which required removing the manifold. NAPA has the parts but cutting that out and welding it back in at camp would add complexity.
You must want to kill all the nuns with this one too.![]()
Dimple plates look good. I would grind that corner of the tower to round it into the front vertical plate so it's got a nice transition for looks.
what if he wants to swap it back to leafs?It's coming along strong. You should paint that header panel before you get too far though, the E-coat will start to surface rust before long. At least mine did. And cut those leaf spring hangars off already. They are going to be crazy rock anchors.
Lookin good Kevin!
I've thought about leaving them for flat towing purposes?what if he wants to swap it back to leafs?
You will smoke those right there....even mine on the front of the frame have taken a beating from Rubicon and hammers.Thanks Brandon!
Good call on painting. I'll shoot it when I paint all the raw metal.
PS: Don't tell me what to do. I'm procrastinating cutting them because there's no easy way to do it cleanly
