Thanks fam...You'll always Stevey Pop to me.![]()
Stock external? Mines in the tank.I had consistent fuel pump relay issues. I never replaced my stock external fuel pump from day one.
I want to say mine was a Motorcraft through Summit
I'm always strugglin' with my beaver. Damn thing won't work with me at all.Any else have issues with these things?
I don’t think they’re all plumbed the same way. Some have 2 pumps LP/HP and some just have 1. Mine had 2. I ditched the wiring for the in tank LP and just ran the external HP.Stock external? Mines in the tank.
It's a pain to test since I haven't cut the hole in the bed yet... but I will now! maybe it's just a bad connection? Either way I'll be swapping in a new 'free' replacement fuel pump while I'm in there.
Mr. @GahnRacing had the mighty 2.5l motor... which is super uncommon to build so maybe that's why neither one of us know about it?I have never seen the two pump setups on Ford rangers. Only Broncos and f-150s. Most likely because they had a dual tank option so was cheaper to put a LP pump in each tank feeding the HP pump on the frame. The HP pump on the frame is what I've used for every LS swap. I've done an e2000 pump
How dare you. He had the glorious 2.9L.Mr. @GahnRacing had the mighty 2.5l motor... which is super uncommon to build so maybe that's why neither one of us know about it?
Thank you BodjHow dare you. He had the glorious 2.9L.
I think I am mistaken. I ran a Bronco II tank and I could have sworn when I looked for fuel pumps for it they had an option for a LP and HP pump.I have never seen the two pump setups on Ford rangers. Only Broncos and f-150s. Most likely because they had a dual tank option so was cheaper to put a LP pump in each tank feeding the HP pump on the frame. The HP pump on the frame is what I've used for every LS swap. I've done an e2000 pump
