The Grand Tracker (Retard TT)
More work through the week. I have Thursday/friday off next week so I’m prepping to hammer down on this thing those 4 days. I’d like to have the frame in, radius arms in and hopefully beams plated with shocks starting to mock up. See what I can get done
Hubs drilled and rotors in with 5/8 studs.
Pass side all torn apart waiting cleaning and new parts!
More shit box work. Busted ass Saturday to clean up all that crap, turn rotor, put ball joints in, new u-joint in axle (will need to pull the stub from the diff still), paint all the shit, drill for the 5/8 studs, install said studs, put new bearing races in, pack bearings, put seals in and make the mother fucker roll.
Can you say “flexy bitch”? That’s a 1/2” f911 bolt that was already preloaded heavy into the knuckle. Shoulda done 2 of them. Also, Dmax main cap work tits as plates for a 12 ton press.
Once rolled up, I feasted my eyes on how well this hot dog fit down this hall way. She’s like my date from prom night, tttiiiiggghhhttt. This thing will probably last longer than me though.
Anyhow, oil pan will be what fights me for room. Still got 2-3” to move the frame back and that’s about what the oil pan has to the crossmember. Those bronco motor mount plates will go bye bye. Might have to mod the oil pan but doable. Before we get that far though….
Need to:
Strip the shock/spring frame mounts
Cut off those tubes going across the frame
Set ride height 2” taller than stock
Roll frame back under rig and play with frame height and clearances.
You guys wanna see something cool?
Took Thursday and Friday off to hammer on this thing. This was Thursday. Yes those jack stands are sketchy as fuck. No nuns were harmed in the process of this build. Stripped the bronco frame. Half ass held the beams in place at about what would be a 2” lift on a bronco and put the frame under the rig to see what will and won’t clear. Basically, everything clears by a nut hair. Not a cunt hair, a nut hair so slightly more clearance than what a cunt hair gives
Frame still needs to go up 1-2” and I may rake the front up to 10*. Wheel base is within an inch of what it was before
Friday:
Started out by setting beams so they were at the same spot front and back and so caster is set. Then lifted the front of frame up to put a rake in the frame. This does 2 things, lowers the ride height more (which I wanted) and closes the gap between core support and frame
Muuuuuch better.
With that all set, I raised the rig back up and wire wheeled the whole top side I won’t be able to get to once welded in and painted it
Then started on motor mounts. After racking my head on this, wound up using the old bronco mounts for the tracker isolators to mount to. Driverside came out tits, passenger side I’m probably going to redo. Mount doesn’t sit flat and puts the mount at a goofy angle
Checked clearance between hood and engine after taking the engine support out letting the whole engine weight onto the frame. I raised the engine up 1” to move this frame up higher. I’ve got atleast an inch between hood and engine.
And then butt welded the two frames together, just top and side for now. Need to trim the bottom and then fish plate it all. I’ll also box the back side of the bronco frame buuuut she’s off jack stands!
And today:
Spent the whole damn day doing the core support mounts and all the frame gussets. Did not think it would take that long, sheesh.
I don’t think it’s going anywhere though
Radius arm day. Basically building it all from scratch. The mounts at the beams, the radius arms and the mounts at the frame
Used 2” .250 DOM for the radius arm, 7/8” heim, and front mount will use a single bolt style instead of two separate bolts on the beam. This gives me more room to add the hydraulic bump stop too. Took a piece of 1.5” solid 1045. Drilled a 3/4” hole in it and made it the through bolt for the radius arm to beam.
Starting with driverside. The 3/4” bolts I got were too short so I used a piece of .75” .120 wall tube so I could just use a 1/2” bolt for now instead.
Initial frame pivot boxes. This didn’t work out. The radius arm was too far under the frame and was hitting the frame before I was anywhere near full bump.
So I kicked the boxes outward an inch and re-tried. It’s fucking tight but shit clears. It will be bumped a little lower than this because the diff is hitting the frame at this point so no need to clearance
I threw a tire on to see what it looked like and didn’t get a pic. The pic above is at full bump. Tire slightly rubs the radius arm at full turn but not much I can do about it. May throw a small spacer on the hub. Tire to fender clearance is good. Enough to fit 35’s and if I do go that route, I’ll probably go a 35x10.50r15. Helps with the tire rub on the radius arm too.
So to fix the pivot boxes, I put a break in the outer tab to go back against to the frame and added some gussets
I might add another gusset from the inner frame edge to the pivot box too. That way it grabs the stronger part of the frame since I didn’t plate the frame. Probably over kill but won’t hurt anything.
Then on to the passenger side. Rinse and repeat. Least I was building things in doubles as I went so this went far faster. Clearance is just about the same as driverside. Guess that means I centered it all well lol.
Pass full bump
Mmmmmm flat links at ride height
Yes! You're killing it! I was going to suggest adding a bend to the radius arms to allow the tire to turn more. I need to remake my radius arms and I'm going to be doing that. My steering angle is garbage.
Can’t. Adding a bend will put the arm back under the frame and now we are back to limited up travel.
The only for sure fix is to basically hack off half of that frame plating/gusset I did so that kick isn’t there but then I’m loosing 2”+ of frame thickness. I’ll take a little tire rub over that. I may reduce the steering angle anyhow to help keep the stub shaft alive when crawling. I’ll see how it drives first
I did briefly look at seeing if I could center mount the radius arms and it looks like I have the room but that meant starting all over with trans crossmember and I’d rather get it back in the dirt sooner than later
Makes sense. What plate thickness are you using for the frame grafting? I did large quarter inch plates and then 1/8" overlays lol
All 1/8”. The bronco frame is just under 3/16 and the tracker frame I already had some plate left on it from the old frame chop I did so after welding the two frames, I didn’t see a reason to go thick shit again. I’ll bend the Suzuki frame before this will.
The pivot boxes are all 3/16” and the beam mounts for the radius arms are 1/4” tabs with 1/8” bracing. When I do the bump mounts I’ll probably make those out of 3/16” as they will most likely incorporate into the beam and radius arm mount. Beams im thinking 1/8” overlays and the open sections I’ll do 3/16” to box in.
