Local Legend Project G4 AKA Quasi-Ghetto
OK, Here is .028.
PS:
Motive tech guy told me he starts with .030 on these gears...and goes from there. go figure.
That's an odd thig for him to say considering it varies greatly between case/pinion support combos. Unless he was familiar with your exact set up I suppose. The pattern looks good but a few coast teeth look a tad deep in the .028 pics, happen to have a shot of the "ghost"/transfer pattern? sometimes it tells a better story. I can see the drive ghost and it looks good.
Yea i think he said it was just his starting point for a new setup with motive gears in a higher ratio like mine.. (when discussing the number srcribed on the pinion head.. def not needing .07" of shim).
when you say ghost/transfer. Are you tallking about when it carries the yellow marking compound over from the painted section to the bare teeth?
I liked looking at that during this process.. seemed easier to read the actual pattern that way
I will get some more pics later. And when you say the coast looks deep... that again would mean to keep pulling the pinion out with additional shim, right?
Yes and yeas. Looks really close though.
OK... here is some more of .028. I wiped a bunch of this marking shit off... I look like I have jaundice now. haha.
It looks pretty dang good to me, but what do I know. LOL. What i noticed is the drive pattern ends right before the middle of tooth radius, where it kind of drops off. It's hard to explain. BUT>>> still seems like it could go out more?
I have a feeling @Raceranger97 is gonna tell me to try a .030 and I dont wanna! So tired of taking this thing in and out now. haha
Okkkkkk. Here is .030. Is it any better @Raceranger97 ? I had to move the carrier spanners this time. Backlash got tighter this time.... Like .004
The backlash options were either .006.. or like .008-.009. So not really in the middle like it was before. Pattern is run here on .008-009
Hmmm. Weird the coast isn’t getting better. For what it’s worth, I built another one just now for a desert customer. Here is the result at .044, but in a completely different case/support.
The worst part about setting up ring and pinions is the constant taking it apart and putting it back together. I have set up a few but I am no expert. It’s usually pretty clear if you start too deep or shallow. I force myself to add/subtract until I overshoot it. Then I look at all the photos and decide which one I like the best. It’s usually a compromise somewhere.
It seems that most people who get it “wrong” at home because they get close, say that’s “good enough” because they are fed up with taking it apart/putting it back together and end up running it at a less than optimal depth.
Lots of good knowledge here on what that sweet spot is.
Also 9” stuff is easy! My Toyota 8.4” requires the inner pinion bearing to come out to adjust pinon depth and shims on the carrier bearing to adjust backlash. Clamshell front diffs are a whole different level of frustration!!
Hmm. Yea yours are way more centered on drive side.. and higher up on tooth too.
Maybe I will go try a .032 and then something big like .040
OKKKK>>>> well this is funny. I'm a total dipshit and apparently took out the .008 and didnt put in the .010!!
SOOO>.. that last pattern was actually .020. Jesus. NO wonder the backlash went wrong way.. and no wonder the pattern was worse.
I will get the pictures of the .030 pattern for real now. When i took it apart i was like ohhh. DERRR DA DURRRR. Wonder if I was drunk on that one. Dont do drugs kids. LOL
Here is the actual .030 pattern. now that i have done this like 9x ... I have removal and re-install speeds in top shape, that is for sure. LOL
Shit looks pretty good to me. But I assume I should still take a look at .032 or .034 or ??
@Raceranger97 Are you focusing more on the drive side or the coast side when you look at it?
I had "Elsa" helping me "paint".
I'm no axle pro like Axle pro's is but I like that.
Now add another .002 and try again. Lol
AHAHAHH. Seriously. I would throw this one in for sure. I have another .003 shim staring at me though.
OK>>> so I dunno. I seem to suck at this. LOL. Been trying to break them in slow. Everything seems great up tp 45mph. Did a couple like 10 mile sessions in neighborhood letting it cool completely. Then today I tried to take it on just 1x small portion of freeway. Coast was super loud. What really stumps me is on the drive back. I can get it up over 55mph in 2nd ... but it didnt howl on coast. If i take it up to 55 mph in 3rd and let off.... I swear it will howl. WTF. I'm about to just buy a whole predone 3rd at this point. hahahha
