the_fablab_
- Apr 15, 2022
I can also get you a third for that price from moser
Oh, and is this lack of clearance an issue too or what? The last ring gear self clearanced a tiny bit off the aluminum case. These 5.43 pinions are way tiny compared to the 4.56 I pulled out, and seem to have the ring gear too close to that pinion support area of case. I wonder if these Ultra Case's aren't really designed for off road and gearing? orrrr, I have something drastically wrong. LOL
@Raceranger97 am I fucking up here? LOL
did you install a full restomod air system in this? I am about to pull the trigger on their system for my 56... any feed back you have would be great... did you get the bluetooth unit?G4 put in some work at Terra Crew. The trans temp issue "came back"... but I was being real hard on her and it took a bit to get it that hot. (I would stop/slow for a bit when it hit 250.) It still does some weird shit with the lurching everytime you start it. I will probably try to add two more expensive ass linear temp sensors and configure them to my Holley so I can know more about pre cooler and post cooler temps.
Also had a stange moment in second session where somehow the engine fans got turned off. I saw engine temps were over 250! Oopsie. Pulled off track and took a moment to figure it out. Numbers climbed as high as 270 when it was sitting there off... and puked out some coolant. Turned fans back on cruised for a second... whala.. back to 205. I must have hit the switch somehow?? I think I will change my oil now. LOL.
Oh and the Restomod Controls apparently arent rated for such shenanigans. Two knobs left the chat. The first, I dont know when... and I found it in the cab... the second happened in the big rollers, so I pulled over and handed it to my co driver, "here hold this for a while". haha
oh, and I should add the heater works awesome and so does defroster. The defroster(and wipers) were actually a part of bigger picture for me. On desert nights sometimes you need it.. unless you wanna play scrubb a dubb dubb all up on your windows with a rag. been there done that.
you just reminded me I till need to figure out a way to add window squirters! The list is never ending I tell ya.
