theycallmeWALLY
- Mar 30, 2022
Which Swingout bearing or whatever they're called did you go with?
The ruffstuff axle bearing style. https://www.ruffstuffspecialties.com/STIRES.htmlWhich Swingout bearing or whatever they're called did you go with?
looks clean dude ! plus 5 points for the Sport Chalet license plate frame...Added some support toobs and paint
View attachment 3786View attachment 3787View attachment 3788View attachment 3789
It’s been glued back together, wish I could get my hands on another!looks clean dude ! plus 5 points for the Sport Chalet license plate frame...
Haven’t done much to it, life and work have been busy. Gonna have to reengineer the swinger, even with rubber isolation and floating mounting bolts it deformed the body a little so that’s on my to do list. No biggie. Also have to scotch brite all the exposed metal on my front end and the paint it. Plan to do that when I have a couple weeks off for Christmas. Maybe even get some dez time in if I can. Was really hoping to get more trips in this season but it seems like every time I’m off work there’s something going on lolbumpity! Hows this thing coming ?
right on dude... you guys planning on getting out to KOH?Haven’t done much to it, life and work have been busy. Gonna have to reengineer the swinger, even with rubber isolation and floating mounting bolts it deformed the body a little so that’s on my to do list. No biggie. Also have to scotch brite all the exposed metal on my front end and the paint it. Plan to do that when I have a couple weeks off for Christmas. Maybe even get some dez time in if I can. Was really hoping to get more trips in this season but it seems like every time I’m off work there’s something going on lol
I’d like to, you guys doing a trip out there?right on dude... you guys planning on getting out to KOH?
yea mon! come hang out !I’d like to, you guys doing a trip out there?
Yeah I was really hoping my floating bolts and urethane isolation would help that but no dice. Luckily it wasn’t worse.that will solve it. cant really have one point mounted to the frame, one to the body with out flex issues over time.
Dang dude a little? haha sound like you’ve been busy! Hope all is well.Sup bros. Long time no post. A little bit has happened to the runner, not much. Went through a few gas tanks that kept cracking at the exact same spot, replaced some motor mounts, yanked the tire swinger bumper, and blew a head gasket, then wiped out a cam, then swapped in a junkyard 22RE with 100k on the clock last weekend. Did get to finally gusset in my hoops and replace my a arm bushings a couple months ago. Need to rebuild my shocks and probably soften all the stacks by one step thinner shims.
Haven’t gotten to do much offroad fun this past year, hoping to change that now that I have a new to me motor that is definitely healthier than what came out. Have a couple camping trips planned for this spring. Here’s some photos of stuff I’ve been doing lately.
New to me motor, decided to open it up and replace the head gasket since I had to replace the timing assembly. Had the oem DID chain on it, and the inside looks fantastic. No streaking or anything on the cylinders. I scraped a little carbon off the pistons and valves and sealed it back up with an oem gasket and ARP studs.
It’s running titties. I’m now trying to figure out why my back brakes are screaming constantly. Can’t seem to fix it, maybe I shouldn’t have gone with vatozone brake shoes.
Ha, yea a little more busy than I’d like to be. At least I enjoy wrenching a little.Dang dude a little? haha sound like you’ve been busy! Hope all is well.
Looks good dude.... I like the little step/tire supporter.what’s up bros?
Decided to make a new swinger bumper. The tube one was cool but I started to dislike the tire not being centered on the tail gate. Wanted to go with rectangle tube cause square edged stuff seems to be all the rage these days.
It’s kinda hard for my brain to think in square stuff so this was hard to keep super simple which is what I wanted.
View attachment 25032View attachment 25033View attachment 25034View attachment 25035
Needs a couple gussets here and there but for now it’s done.
I removed my old one cause I thought somehow that was causing my fuel tanks to crack. Doesn’t make sense but that was the only change the runner saw before it started cracking fuel tanks. Took it off and the tanks stopped cracking. Weird.
Hopefully this doesn’t cause it to start happening again cause my wife and I have a camping trip planned for next month in the sierras.
I have some weld on hook points I’ll burn on eventually.Looks good dude.... I like the little step/tire supporter.
What about recovery points?
