Anyone have any leads or know anyone who'd have a dunebuggy.com spindle for sale/who still sells them???
glad papa caught this before something terrible happened in the middle of the dunes. hah
papa is going out to Fodrills right now to ask Denny what his thoughts are.
Doesnt look like he can box in any of that area since the heim/uniball goes in there. I'd probably go the route of making a new spindle with more meat behind that hole but thats just me. Maybe measure it to grab the geometry off of it and see if kartek has anything that matches up even remotely close, if it happened to one side it'll happen to the other most likely.
Do exactly what DR Bodj said. It’s fucking steel. You’ll be done in half a day.
1. Drill the the end of the crack with 1/8”
2. cut those weld washers off
3. grind out cracks to knife edge
4. Make thicker & larger diameter weld washers
5. Fill cracks with weld
6. Weld girthier washers on
7. Smash whoops
8. Fuck bitches
it not only needs to be thicker, but you need more meat around the backside of the bolt hole. It’s too close to the edge. Cut out a plate like what I have drawn, weld it onto what’s currently there inside and out), grind it smooth on the exterior, then add your new overlay plates. Literally half a day job since you already have them off the car.
