Toyotally Awesome 1987 4Runner
moved dip stick capped old port
Changed fuel filter.
Installed motor mounts
Installed Alt and AC Compressor and Belt tensioners
installed oil sump/ pan
installed Fly wheel/ Clutch/ Pilot bearing and throw out bearing.
snapped a bolt in the process... fucking Toyotally Awesome ammo can bails me out again.
Got the motor in with some wrestling... and some chirps from my wife "I feel like this should go together easier?" (that's what she said)
Managed to smash the fuck out of my finger moving the hoist over to pick up the 3RZ... so that was cool
RIP my Finger nail I'm sure.
Good Times.
Now the hard part hooking it up and make it run!
E
More progress this weekend.
Picked up a starter
Motor Trans bolted up
Motor mounts in with the help of the little man
Power Steering lines in and hooked up
Swapped stock harness 2wd A/T out for M/t 4wd harness ECU... Honestly not even sure i needed to do this but wanted to make sure it matched the conversion harness for the ECU info I gave to Offroad solutions.
Ran all the harness into the cab
Ran all the ORS wiring harness out of the cab. and began install probably about 40 % there as far as hooking up and splicing everything where it needs to go
Worked on cleaning all the bullshit wiring on this thing some from when i bought it and some from shit I have added over the few years I have owned the truck..
Looking way better still long way to go.
Also picked up my driveshafts had one prepped front was okay
Rear was completely fucked ( still a good trail spare) ordered a fresh from Tom Woods
A few photos from the shit show.
Current to do list 😑
-Finish connecting adapter hardness
-Fuel Line Connect
-installed Starter
- install headers with shim washers
- figure out intake
- hook up Hoses
-Fan Clutch/ Fan
- install radiator Hoses
- Buy Oil pan drain plug
-install OIL
- Exhaust
-install Drive shafts
- Blead Clutch
- Fill powersteering
- Replace Tie rod ends on steering
-Grease Burfields
- install Half Doors
-Remove Top
- install soft top
- Clean out truck
- buy Battery
- Wire 12 plug for fridge
-Wire Winch
Thanks for coming to my TED talk
E
My beautiful wife cleaned out the truck from KOH yesterday for me. So that cool.
After I got the kids to bed headed into garage around 9pm and decided to take the night off from wiring
got the header/ EGR sorted
and installed the starter.
New oil cap who dis ?
It's getting better? 🙃
Realized need to get a new plug for the 3rz alternator ordered https://a.co/d/32qyGdI
and need a fitting for fuel line ordered https://www.toyotapartsdeal.com/oem/toyota~union~90404-14014.html
- Alt plug
- Fuse Block Ext wire
- Starter Tigger wire/starter plug
- Fuel pump Wire
- Mount Obd2 plug
- 4wd indicator
-motor/body ground
-Fuel Line Connect
- install Starter
- figure out intake
- hook up hoses
- Fan Clutch/ Fan
- install OIL
- Exhaust
- install Drive shafts
- Blead Clutch
- Fill power steering
- Grease Burfields
-Remove Top
- install soft top
- Clean out truck
- buy Battery
-Wire Winch
-Nut and bolt Check
-Fluids
Many Long nights ahead...You can't tell how much fun I'm having... 🤡👌
Over and Out.
E
