badlinesgoodtimes
- Mar 30, 2022
Keyed the truck on and had nothing. tracked it down to fucking up wiring into the fuse box. I figured Id mess with it over at @the_fablab_ while he was working on the exhaust. Rolled the truck out of the garage.
UPS dropped off the Chilkat exhaust cross over pipe and I headed over flat towed it over to mikey's
After messing with the wiring until about midnight with Mikey. I came to the point that I knew I was over my head and out of time as we are trying to get this thing ready for Rubicon trip next Wednesday. I left the truck at the Fab Lab for the weekend to have Jesse who is a wiring wizard.
After fixing a the fuse panel situation and correcting a some of my wiring fuck ups (I had a few power wires that were grounded to the body) and a fresh mass air flow sensor. they got the truck started.
But would die something was up with the pinning in the ORS harness. They worked with ORS and got things sorted.
Yesterday I showed up to the shop and took the truck for a rip... andddd holyyyyyy shit... what a difference so stoked !
Flat towed it home. Checked Fluids and installed new coolant reservoir.
Took the whole fam out for a rip and it was smiles all around.
Drove the truck to work today and shes a ripper!
STOKED!
Still have a some work to do before the trip but I feel like a weight has been lifted off my shoulders.
Current to do list
-Finish connecting adapter harness
- Fuel pump Wire
- 4wd indicator
-Reverse light indicator
-Coil Tigger wire
- install battery Alt Starter harness
- Alt plug
- Starter Tigger wire/starter plug
-motor/body ground
- Fuse Block Ext wire
- Mount Obd2 plug
-Fuel Line Connect
-install heat shielding on firewall. Glad I waited til motor was back in!
- install Starter
- install headers with shim washers
- figure out intake
-Swap out 22re oil pressure sensor
- hook up heater hoses
- install radiator / Hoses
- figure out vacuum lines
- Fan Clutch/ Fan Shroud
- Buy Oil pan drain plug
- install OIL
- Blead Clutch
- Fill power steering
- buy Battery
- Exhaust
-Order O2 sensors
-weld on bungs
-exhaust flange
- Connect o2 sensors
- Replace Tie rod ends on steering
- Grease Burfields
-remove doors
- install Half Doors
-Remove Top
- install soft top
- Clean out truck
- Wire 12 plug for fridge
-Nut and bolt Check
- check Fluids
Back to the grind tonight.
STOKED!
Current to do list
- Fuel pump Wire
- 4wd indicator
-Coil Tigger wire
- Alt plug
-motor/body ground
- Mount Obd2 plug
-Fuel Line Connect
- install Starter
- figure out intake
- install OIL
- Blead Clutch
- buy Battery
- Exhaust
-Order O2 sensors
-weld on bungs
-exhaust flange
- Grease Burfields
-Remove Top
- install soft top
-Nut and bolt Check
- check Fluids
