Baconcreekmetal
- Mar 18, 2023
Dang!
I honestly don't recall last time I checked it, but it appears that the foam in the cell started to deteriorate. Both filters cleaned, foam removed and carb cleaned and re-sealed. Hoping to test soon to verify the problem is fixed. Going to be changing the shock shims as well so we can start actually dialing in the front end, currently every bypass is open and it is still too slow.Shit, what's you story with the filter? How long has it been in the truck
what size are those wildpeaks 37?. Swear those things run small as hell... buddy said he likes how they grip though..
Yes, the rear could probably be dialed in better, but it’s always worked well enough for me to not bother with it. Front took big hits well, but was really aggressive in the small stuff. Hoping I didn’t overcompensate..ok.. so you talking about fronts.
I have .015's... can't rememberif doubled or tripled on main shim. It feels a bit too stiff in front, but i havent turned many tubes yet.
Thanks man, I’ll for sure do that if this doesn’t get me close enough.If you ever need shims hit me up! I can build you some stacks of recommend for your setup too vs just straight valving stacks from king
It happened while making some mild passes down main. Bottom of main was upsetting the truck quite a bit since the shocks were still pretty far off, heard a pop and it got a little extra wild for a sec but nothing major.had a feeling 12's would be too little damping...
and how did that feel when sway bar broke... one of my fears is mine breaking in a hard corner and causing a roll over...
He enjoys revalvingjust straight .015 pyramid stack? nothing doubled up or anything?
I'm open to suggestions, haven't done it yet.just straight .015 pyramid stack? nothing doubled up or anything?
