Dimples the power steering resi with some stuff laying about
Bent up the last piece of sheet
wraps tight on the drive shaft loop on the rear
a couple 1/4" screws hold the bottom of both sides down on the floor flange
the front will get stitched up and the whole thing glued once it is time
When I swapped oil pans a while back these bits where in the bottom of the couriers old motor. Might need new belt tensioners
