Dimples the power steering resi with some stuff laying about
Bent up the last piece of sheet
wraps tight on the drive shaft loop on the rear
a couple 1/4" screws hold the bottom of both sides down on the floor flange
the front will get stitched up and the whole thing glued once it is time
When I swapped oil pans a while back these bits where in the bottom of the couriers old motor. Might need new belt tensioners
geeking out on my own EFI again so i needed a hall sensor on the crank first thing. got a dodge journey cam sensor and just turned it down a little to fit with new O-ring groove. i needed the plug to come out straight with no elbow. bolts right in now
