in case no body looks at the first page any more
  • $94 – Fuel cell
  • $55 – EFI fuel filters
  • $30 – Fuel cell fill cap
  • $26 – Fuel pump relays (x5)
  • $25 – EFI fuel pump
  • $20 – Fuel cell fittings
  • $15 – Fuel pump to filter couplers
  • $13 – Fuel pump fittings
  • $10 – Fuel pump fuse block
  • $9 – Fuel pump tray isolators
⛽ Subtotal: $297.00
  • $1,100 – ARB air locker
  • $390 – Ford 9" cut-to-length axle shafts
  • $213 – Rear brake calipers w/ pads (Nissan 240SX)
  • $150 – Junkyard 9" complete axle
  • $125 – Cheap 9" gears (4.11)
  • $71 – 9" third member rebuild kit
  • $57 – Rear disc rotors (Grand Cherokee)
  • $33 – Air locker pump
  • $24 – Rear caliper brake hoses
  • $22 – 9" axle retaining plates
  • $16 – Rear brake caliper banjo bolts
🛠️ Subtotal: $2,211.00
  • $1,000 – For the car
  • $667 – Wheels
  • $625 – Rear coil over shocks
  • $600 – Transmission
  • $577 – 2"x.120" (5x round, 1x square) tubing; 4x10 C.R. 18GA sheet
  • $570 – 3.0L Formula 1 engine
  • $290 – Rear tires (255x60R15)
  • $279 – China racing seats
  • $163 – Front tires (225x60R15)
  • $144 – 6HP26 yoke (1350 series)
  • $140 – Battery
  • $117 – DOM tube for 4-link
  • $112 – Steel for fuel cell / battery mount
  • $88 – 1/4" steel plates for 4-link mounts
  • $75 – 4 link rod ends
  • $72 – 4 link bushing ends
  • $70 – 6x Toyota 3.5L COPs w/ pigtails
  • $60 – Labor to mount tires (Les Schwab)
  • $57 – 1/4" x 2" flat plate (driveshaft loop / chassis)
  • $42 – Engine/trans mount bushings
  • $32 – Crank and cam sensor connector ends
  • $29 – Silicone radiator hoses
  • $26 – Spark plugs (Autolite #103)
  • $20 – Header bolts (16 socket head screws, 8mm)
  • $20 – Cam hall sensor
  • $17 – Rear shock bolts (1/2" x 3")
  • $16 – 20x 1/2" lug nuts
  • $15 – Bolts for fuel cell and battery mounting
  • $10 – PCV valve
  • $9 – COP screws x6
🧰 Subtotal: $5,791.00
Grand Total: $8,299.00 for a shitty old dodge colt!
