I might have to get weird on the driver's side motor mount. There ain't shit for easy mounting. Only two 10mm on each side of the filter
Drivers side motor mount done.
Soft side has 4x 10mm bolts into the block and the wheelie side has 3x 8mm bolts into the block
Perfect :cautious:
with the semi rigid mounts, i am going to mount the alternator and possible the power steering pump to the frame and run the belt all over the fucking place
got a little more to go still but it did go kind of smoothly.
the A pillars where the only real trick. i surprised my self there and didn't fuck them all up.
even got most of the notch's tight.
Ok, all current cage is welded hot 100%
plan for the main hoop laterals. i need the bottom triangle to drop out for drivew shaft clearances
Just need one more stick for the main hoop laterals! Dam
