the bodj
You’re using 12” shackles, correct?
So what is your number from center to center if not the magic number, mine was set at 53.5” give or take so I plan on moving it forward 1”. I’m not sure of the valving but the guy I purchased them from said it should be pretty good for my set up also having the adjusters could help it when I fully load it.Tech talk and sharing knowledge it what build threads are about. I tried the “magic number” when setting up my springs and the spring eye hit the frame at bump. There was really only one spot where the spring didn’t hit the frame and the shackle didn’t go past 90 degrees at droop. It was pretty sensitive to positioning though, like a 1/2” one way or the other make things go bad.
My upper shackle mounts are also as close to the frame as possible and nothing hits now. Well the tires will rub the bypass tube, but that’s because I didn’t account for how much lateral movement a leaf spring live axle will have.
Also I have pretty mellow shock valving and will probably make it even softer as I’m not using all the bump travel and pushing the truck as hard as the front end will allow.
Yep. 12” center to center.You’re using 12” shackles, correct?
Center to center is right at 53.25.So what is your number from center to center if not the magic number, mine was set at 53.5” give or take so I plan on moving it forward 1”. I’m not sure of the valving but the guy I purchased them from said it should be pretty good for my set up also having the adjusters could help it when I fully load it.
Correct, I tried it, but the spring hit the frame before full compression. Had to move them back a little.I'm pretty sure the magic number was 52.5"
I know zero about shocks or tuning of shocks, I bought fox remote dsc reservoir 16x2.5 and I believe they said it’s a 50/70 valving which I know nothing about. I had mine at around the 53.5-54” range so I’m moving it forward now which hopefully lowers it a little also. My build is more of the handyman which works on all but not specifically great at any type of off-road. I’m sure whatever the outcome is it’s will handle the whoops better than my xj and flex ok on the slow stuff minus the front end ifs. Living in Southern California I see more desert terrain than rocks.Yep. 12” center to center.
I’m running 16” King 2.5 2 tube bypass shocks. A combo 12/15 stack on compression and a 8 stack on rebound with the bleed hole plugged. Also a .125” hole drilled in the rebound poppet. Tubes are both basically all the way open.
I plan on swapping the compression stack to all 12’s to see if it works better.
That's just the internal parking brake I think.pshhhhh drum brakes. Broke bishhh
Remember, your tax dollars pay my salarypshhhhh drum brakes. Broke bishhh
Correct on both! Parking brake inside the rear rotors and I am broke.That's just the internal parking brake I think.
they pay mine, too!Remember, your tax dollars pay my salary![]()
oh shit! It's a Lyfestyle haha, shoulda hit me up I woulda cruised out for recon... Glad you made it out safe!Home safe. Damage report, one exploded modified tundra CV shaft, ripped off mirror and some dents. Definitely bruised my ego a little bit too. At least the boy has some good memories.
View attachment 15341View attachment 15342
Thanks!oh shit! It's a Lyfestyle haha, shoulda hit me up I woulda cruised out for recon... Glad you made it out safe!
So you guys got stuck, had to camp there and then @the bodj came to the rescue the next morning?
Gorman is nice that’s is close to me and has a little bit of everything. It’s definitely a little small though, especially in a “high speed” vehicle.I miss Gorman. Nice seeing some pics of that place.. Soo sounds like some Baja Designs should be next on your to do list.
