Been plugging away. Changed out front firewall bulkhead to square one with smaller tighter boots. Also put Noico sound deadener and foam on most of that part of firewall...
And made the holes for the black one I have on the way for ground. And made ground cable to back. Still waiting on fuse blocks so I can wire batteries in.
Made the ground cable that is inside cab. Boots on everything. Gonna have to change name on instagram to "DasBoot" Also have the holley ECU main power and grounds done.
And then wired in the grounds for AC and both switch pros. Also finished wiring the 4 high current outputs on Switch Panel B. **Don;t worry... once I do the final, final install on those 3 grounds, I will put some heat shrink on the loom. The split loom has grounds for SwitchPros that split out of it up in the front, and don't want to make that permanent yet.
Tell you what, I have a LOT of time in this already... the main battle for me is trying to wire it cleanly. So, trying to lay it out like a harness takes a lot of thought and practice runs of what will go where and what need to be spliced where....
"and would you look at that... just look at it."
