sand_in_my_mouth
- Mar 10, 2025
Hey there,
My son and I are working on project to be a DD + camping + light off-road rig (prelander, I guess). It's a 1996 F-150 with stock 302 and 4R70W (auto 2wd) transmission. We're converting the truck to 4x4 and have a year do it while he gets his license. It's a super cab short bed (so has the long drive shafts/carrier bearing).
To get started, we bought a non-running donor truck, which is a 1992 F-150 with 302 and M5OD manual trans and directly attached BW1356 manual t-case. The axles are factory 4.10s (Dana 44 TTB front with manual hubs and Ford 8.8 rear). The donor is a standard cab short bed, so a much shorted wheelbase than the DD we're converting.
We basically bought the donor truck for the axles, dash, door panels and a few other parts. Even though the factory 302 is a dog, I think that the 4.10 axle gearing will be fine for skinny 35s on 15" wheels (i.e. low rotational mass). We want to keep it stock width and mid travel for now, so I ordered some Desolate suspension parts. I'll probably add a lunchbox type locker to the rear.
I'm trying to get my head around the transmission + transfer case setup.
I'm probably wrong, but I ~think~ that these are the most obvious options:
PS- Here's the truck as it sits today with cast beams and 31s.
- Factory style retrofit- Find/buy a 4R70W / AODE with 4wd tail/adapter. I'm not sure if this would bolt directly to the BW1356 and if the shaft output from my trans will work. It seems like I might need a new crossmember and possible an ECU from a 4wd '96 f-150. And maybe a new transmission wire harness? Any feedback on this option is appreciated.
- Divorced t-case- It ~seems like I could run a short shaft from 2wd 4R70W to some divorced t-case, like an NP205. This is my own made-up idea, so maybe I'm way off. I'd need to determine how best to shift the NP205 (or whatever divorced case would be strong, fit, work best, etc.). This seems like it might be the easiest and cheapest, but I'd need a t-case support/crossmember, and some custom driveshaft work. Seems like I could get good angles and have lots of strength. And it seems like I could forgo any electronic issues. But maybe I'm way off? Otherwise, I like this option because it keeps the trans in place and all work basically occurs behind it.
- Manual transmission swap- Obviously, I could try to swap the donor truck's M5OD and mated BW1356 into the supercab. I've read that I'd need a new ECU, new steering column (also from donor truck), and obviously the clutch/pedal/shift assembly, and perhaps this would be an electronics nightmare because of the pre-OBD2 to OBD2 issues. My son wouldn't mind a manual transmission, but this seems like the most work.
- Variant of manual trans swap- Same as above except find a ZF 5-speed manual to use instead of the M50D. This would be burly, but probably no easier (and more expensive).
- Reliable- We want to get many years of use for around town, nearby camping trips, and moderate off-road capability, i.e. just for fun.
- Budget-friendly- I figure/hope that the 4wd swap will be $2k - $4k, not counting axle rebuild/refresh, suspension parts, etc.
- Homemade- I'm an average mechanic, but just bought a small welder and am not afraid of mistakes (I'm good at making them ;-) My son and I want to do as much of this project together as we can.
