Locked Off Road Shocks
04sporttrac
Redmond, Oregon
Anyone have experience with locked off road shocks?
Debating between locked or fox performance series.
I live in Oregon, truck will be mixed use.
Not a super serious go fast prerunner build.
Plans:
Front- Stock width d44 ttb 2.5"x12"
Rear- 4 link shock off the axle 2.5"x16"
I like locked shocks riley is a good dude and will get you taken care of, ive worked on them a few times and they are pretty good for the price.
this bronco is running a 2.5 3 tube locked bypass in the rear.
Why between Fox and Locked?
Seems like two very different levels of shocks as far as brand recognition.
The entry level fox performance series are priced very similarly to the locked shocks.
I would imagine the higher end factory series from fox is of no comparison.
I don't see many running the locked and was curious if anyone had experience.
These days I don't think you can go wrong with fox or king.
between the two I would give the Locked shocks a go if they are similarly priced. The fox performance series leaves a bit to be desired if your going for actual performance. EG. plastic IFP, cast pistons. If your just looking for a bolt in shock on a daily driver then pick your poison. Just my 2cents.
