Hoopdee 94.0 Bronco
I was thinking nut serts I was just unsure how sturdy the factory sheet metal is.
Vibration isn’t that bad on that area of the body like the front so it’s works really well for me my front tube structure has met its end with the flex the frame has from not being caged and needs a replacement plus I’ve seen so many other trucks do the same with no issues and you can bend the sheet metal to make the tabs if needed
Late to the party... I used nutserts and Auto Fab body panel mounts for the Bedsides. They've taken a good beating and still holding up!
