the bodj
Welp the motor and trans mounts are in place and it's sitting without the hoist. I have to raise the motor one more time to fully weld all of the motor mounts (frame and block side), but the location is finalized, and I was able to 100% reuse the old trans mount, just 1/4" off from where it was. I also popped the driveshaft on, so that's sitting in place. I'll have to pull the rear shocks this week and cycle to make sure everything is still good with the amount of slip.
I also got Vbands burned onto the Hooker manifolds. They're definitely warped (200 amps to get into the thick cast steel), so the mating Vband won't sit inside. I'll have to bring them to Mikey's shop this week and turn the mating set down a hair on his lathe
Onwards and upwards.
