1982 F250 single cab
Okay got some work done,
Starting with the fuel tank, currently I'm using the LMC spacers to install the larger tank, I definitely have something better in mind for this.
For the lower chafe protection I used VHB tabe, this stuff always works good:
I sprayed the rear axle with some rubberized POR, I like how it came out.
View attachment 29278View attachment 29279
I did a quick adjustment on the rear bumps by removing the top out spring and replacing it with a spacer to convert the bump from a 4" stroke to a about a 3" stroke.
Shocks and axle bolted in:
View attachment 29284View attachment 29285
Still need quite a bit of hardware adjustments
The overload springs turned into limit straps, I knew this was gonna happen but needed everything assembled to figure out what length shackle to make.
Travel looks promising with the oem 1g shock, maybe I can switch to a 2g or bolt in raptor upgrade later.
Gotta have the bling strike plate!
View attachment 29291View attachment 29292
For this truck, it's a manual transmission, so I NEED a parking brake, I installed a lugnut4x4 rear disc conversion for the D60 with the catty calipers. I hate the long passenger side cable that crosses over the axle... so I am using 2 driver side cables and a bar to pull both sides equally, you can pretty much see what im planning to do here:
View attachment 29289View attachment 29290
Most of the rear stuff on, save for some missing hardware here and there;
there was a dude on go fast broncos making really cool straps for the 38 gallon fuel tank swap named matt lane, ill see if i can find a pic, i had them before then had mikey (only1mikey) make me a really cool fuel tank skid later
Thats legit! I'm thinking about working something in for with my hitch receiver.
And I already made this drop bracket for the rear straps:
Soooo anyway I figured I should start working on this again.
So I finished modifying the beams, at first I was thinking about getting them cut and turned but decided its just not need for my expected travel.
Basically just desolate radius arms and coilover mount. Im building the truck side of the mount with some universal style ruffstuffspecialties mounts. 20250104_172531.jpg20250104_180747.jpg20250426_104606.jpg20250426_160658.jpg
Got the front left shock in position and semi welded. Going to do the rest when I take the motor out. Working on bump stops now. 20250802_122114.jpg20250802_122125.jpg
Also because I want to pull the front fenders and bumpers I wanted to build a light bar and test fit it. The lights are pretty budget but honestly the light bar is more for that cool look anyway. This is what I came up with for using the stock bumper.
Switched out the stock bolts with some 1/2" eye bolts and made some 1/4" plates for the ends. I got a tube laser cut to mout the lights on. :
20250802_144455.jpg20250802_143219.jpg20250802_143316.jpg20250802_144506.jpg20250802_144745.jpg20250802_143309.jpg
Over all state
Very exciting! Not much castor at bump. I usually do 12 to 18° at ride height. Anything less than 10° with the coil over doesn’t handle that well.
Exllent information. So I did actually build these shims that can go between the aft radius arms mount and the frame which will give more caster into the beams.
The problem with my idea is that its a one shot deal because I will have to drill the holes in the frame for the side of the radius arm mount lower. So I haven't done that yet. I am also concerned with the pinon angle.
My question is how do you normally add caster in at this stage? Just with the design of the mount?
Thanks!
