2UZ 120
- Oct 31, 2022
Starting to think about that Shockproof 250w for the rear diff once it's broken in.I've killed one like that before to, 4.56s and all. Took 2 off the pinion gear and 4 off the ring gear. I suspect it was from shock loading it over time because when mine blew, it was not under load. If you got 4 years out of it, that probably a good sign you can put off a full housing for a bit but it may still be worth doing.
