Baconcreekmetal
- Mar 18, 2023
Great idea with the hair clip to clamp the wires together. That'll save me a ton of zip ties.
I ordered 2ft of every wrap prowire sells to see what I like. Doing insultherm at the exhaust portion and then probably just some like f6 split loomWhat are you going to use for loom material once the wiring is complete?
Yea I remembered at the end haha. Having different colored zip ties helps, Walmart sells this bottle with white black green and yellow zip ties so they work good with cutting wires and marking for splices etc. I’ve probably used over 500 already hahaGreat idea with the hair clip to clamp the wires together. That'll save me a ton of zip ties.
Yea, gonna raychem it and do boots?
Looks sick.
One note, and maybe I'm seeing it wrong, but ideally you would have the sockets (f) as the power side of the connector. And the pins (male) on the Non-power side. Think plug in your house.
I think that’s how I have it setup? The idea is leave the male side with the pins on the stationary plug that stays at the rear wall, if the pins were on the removable harness side you’re dragging around male pins that are sticking out with a chance for failure. Female side is on the removable end
Honestly shorting has never even crossed my mind so I appreciate that. The truck will have a battery cut off switch that I would switch off before I mess with anything electrical, like a house.Copy yeah that makes sense, I was just referring to: if you disconnect the connector, the side with the male pins should have no power. This way it's harder to short. Honestly it not a functional thing just something to think about.
Like I mentioned you wouldn't want your house to have "prongs" sticking out of the wall and the toster to have a socket, that's the principle, it's also carried over in automotive wireing for the most part as well IE why the ECU has pins ... because the power goes to it so they can't short.
This is probably what you need assuming that's a Deutsch connector View attachment 20373
It’s an hdp20 connector. 29 way using solid contact pins. It’s a DT connectorWhat connector do you have?
