Vans HD build LSK
I would have agreed with you when I built this but the dually AAM 11.5 axle is 670lbs with brakes and fluid. It keeps mule kicking even after 300lbs of ballast, and a couple of re valves.. The front works so well and I really want the back to keep up. The 9" is also just more fun to add link pivots to and looks a little cleaner. That ford is awesome I keep telling people to build those old super duties.
Wow, that is very heavy! Thanks for being one of the coolest guys in our industry and proud of what you’ve done, you have earned your piece of the pie.
Building a revised version of this kit that should be about 90" wide instead of 94". 16" bumped and strapped should still be possible and stay within RCVs recommendation on the inner CV angle. Got rid of the high clearance lower arms because they're a pain to get a normal jack on. Adding machined tie rods, and machined swingers. Should look a little less ridiculous.
