Uncle Eddie bronco build
Well picked up some king 2.5x12’s for the front today. New used for mock up then the truck was parted out. $1000 for the pair. Ordered for a f150 so valving should be close
Can’t wait to get this thing done. My dad’s Bronco is almost ready just ordered springs last night then mine gets to go on the hoist and not come off till it’s done. Last night I finished setting up my gears in the new third member. 5.13 and a 35 spline spool. Also started to tin the dash in
Picking away more and more tied the engine cage to the main cage, needs more yet but it’s a good start.
My boy loves helping he helped my with the dash panels and notching tubes. Even tacked some parts together for my dads Bronco
Turned the ID on some rotors to fit over the rear hub.
Pot miss you headlights in and made a skid plate for the front bumperIMG_2683.jpeg
Started skinning the dash and council the main dash and council top are all 1 piece.
Took a half day at work Monday and Spent the day welding. Finished all the inside cage welding and shock mounts. Still have to finish weld the rear seat mounts but that’s a quick job. Built my rear bumper
Built my 3” y pipe
Built a custom steering column.
Put a few things on my center council
My boy helped me tin the top of the dash.
LOVE IT.
Buuuuuuuuuuuut, if you ever/when you need to fuck with wires and shit behind the dash............ its going to be a pain since you have to take the whole dash panel AND the center console off. Especially if you have a bunch of switches/random shit plugged into the center console area. plus, you'll have to move your beer to an UNstable spot. which COULD be a MAJOR FAIL, in my opinion.........
OTHERWISE, KEEP ON KEEPING ON! LOOKS TITS!
LOVE IT.
Well all my wires are under the middle on the firewall, Switch pro controls everything. So only wiring under the council will be the window switches and battery cut off. Gage panel will be hooked in to the obd port so no wires there. Side panels will be removable if I need access
right on, you got it figured out!
only thing i still have to point out is..................
center CONSOLE, not council. we're not in court here. hahahh
