turbomonty
I am going to do what no man should do ... Keep track of the cost on this thing
Rear Axle Subtotal: $1,915
its go time boys. i know a bunch of you have built some cars so i will ask for help along the way!
1975 dodge colt
2010 duratec 3.0l with a cheap 3586 or 3076 turbo ~450HP
jaguar 6hp26 6 speed trans again
9" rear with 4:10 and an ARB
maybe 26x10 R15 tires
i got most of the large dead parts chopped off now
plans are to build light but likely will weight a touch more than the factory car weight of around 2,100 to 2,200 lbs curb weight
would like to do the minimal cage to be 10.99 legal. plus it is a rust bucket now
i had chatbot make me a bumper sticker
- $1,100 – ARB air locker
- $390 – Ford 9" cut-to-length axle shafts
- $150 – junkyard 9" complete axle
- $125 – cheap 9" gears (4.11)
- $71 – 9" third member rebuild kit
- $57 – rear disc rotors (Grand Cherokee)
- $22 – 9" axle retaining plates
- $1,000 – for the car
- $667 – wheels
- $625 – rear coil over shocks
- $600 – trans
- $577 – 2"x.120" (5x round tubing, 1x square) tubing; 4x10 C.R. 18GA sheet
- $570 – 3.0L Formula 1 engine
- $290 – rear tires (255x60R15)
- $279 – China racing seats
- $163 – front tires (225x60R15)
- $144 – 6HP26 yoke (1350 series)
- $140 – battery
- $112 – steel for fuel cell / battery mount
- $94 – fuel cell
- $75 – 4 link rod ends
- $72 – 4 link bushing ends
- $70 – 6x Toyota 3.5L COP's w/ pigtails
- $60 – labor to mount tires (Les Schwab)
- $57 – 1/4" x 2" flat plate (driveshaft loop / chassis)
- $42 – engine/trans mount bushings
- $32 – crank and cam sensor connector ends
- $29 – silicone radiator hoses
- $26 – spark plugs (Autolite #103)
- $20 – header bolts (16 socket head screws, 8mm)
- $20 – cam hall sensor
- $16 – 20x 1/2" lug nuts
- $15 – bolts for fuel cell and battery mounting
- $10 – PCV valve
- $9 – COP screws x6
Grand Total: $7,689
1975 dodge colt
