turbomonty
I am going to do what no man should do ... Keep track of the cost on this thing
Rear Axle Subtotal: $2,167.64
Remaining Components Subtotal: $5,521.00
its go time boys. i know a bunch of you have built some cars so i will ask for help along the way!
1975 dodge colt
2010 duratec 3.0l with a cheap 3586 or 3076 turbo ~450HP
jaguar 6hp26 6 speed trans again
9" rear with 4:10 and an ARB
maybe 26x10 R15 tires
i got most of the large dead parts chopped off now
plans are to build light but likely will weight a touch more than the factory car weight of around 2,100 to 2,200 lbs curb weight
would like to do the minimal cage to be 10.99 legal. plus it is a rust bucket now
i had chatbot make me a bumper sticker
Rear Axle Components
Item Description | Cost |
ARB air locker | $1,100.00 |
Ford 9" cut-to-length axle shafts | $390.00 |
Junkyard 9" complete axle | $150.00 |
Cheap 9" gears (4.11) | $125.00 |
9" third member rebuild kit | $71.00 |
Rear disc rotors (Grand Cherokee) | $57.00 |
9" axle retaining plates | $22.00 |
Rear disc brake calipers, pads, hoses, banjo bolts | $252.64 |
For the car | $1,000.00 |
Wheels | $667.00 |
Rear coil over shocks | $625.00 |
Transmission | $600.00 |
2"x.120" (5x round, 1x square) tubing; 4x10 C.R. 18GA sheet | $577.00 |
3.0L Formula 1 engine | $570.00 |
Rear tires (255x60R15) | $290.00 |
China racing seats | $279.00 |
Front tires (225x60R15) | $163.00 |
6HP26 yoke (1350 series) | $144.00 |
Battery | $140.00 |
Steel for fuel cell / battery mount | $112.00 |
Fuel cell | $94.00 |
4 link rod ends | $75.00 |
4 link bushing ends | $72.00 |
6x Toyota 3.5L COPs w/ pigtails | $70.00 |
Labor to mount tires (Les Schwab) | $60.00 |
1/4" x 2" flat plate (driveshaft loop / chassis) | $57.00 |
Rear shock bolts (1/2" x 3") | $17.00 |
Engine/trans mount bushings | $42.00 |
Crank and cam sensor connector ends | $32.00 |
Silicone radiator hoses | $29.00 |
Spark plugs (Autolite #103) | $26.00 |
Header bolts (16 socket head screws, 8mm) | $20.00 |
Cam hall sensor | $20.00 |
20x 1/2" lug nuts | $16.00 |
Bolts for fuel cell and battery mounting | $15.00 |
PCV valve | $10.00 |
COP screws x6 | $9.00 |
Grand Total: $7,688.64
1975 dodge colt
