turbomonty
southern oregon
I am going to do what no man should do ... Keep track of the cost on this thing
🛠️ Rear Axle Components​
Item DescriptionCost
ARB air locker$1,100.00
Ford 9" cut-to-length axle shafts$390.00
Junkyard 9" complete axle$150.00
Cheap 9" gears (4.11)$125.00
9" third member rebuild kit$71.00
Rear disc rotors (Grand Cherokee)$57.00
9" axle retaining plates$22.00
Rear disc brake calipers, pads, hoses, banjo bolts$252.64
🔧 Rear Axle Subtotal: $2,167.64
🧰 Remaining Components​
For the car$1,000.00
Wheels$667.00
Rear coil over shocks$625.00
Transmission$600.00
2"x.120" (5x round, 1x square) tubing; 4x10 C.R. 18GA sheet$577.00
3.0L Formula 1 engine$570.00
Rear tires (255x60R15)$290.00
China racing seats$279.00
Front tires (225x60R15)$163.00
6HP26 yoke (1350 series)$144.00
Battery$140.00
Steel for fuel cell / battery mount$112.00
Fuel cell$94.00
4 link rod ends$75.00
4 link bushing ends$72.00
6x Toyota 3.5L COPs w/ pigtails$70.00
Labor to mount tires (Les Schwab)$60.00
1/4" x 2" flat plate (driveshaft loop / chassis)$57.00
Rear shock bolts (1/2" x 3")$17.00
Engine/trans mount bushings$42.00
Crank and cam sensor connector ends$32.00
Silicone radiator hoses$29.00
Spark plugs (Autolite #103)$26.00
Header bolts (16 socket head screws, 8mm)$20.00
Cam hall sensor$20.00
20x 1/2" lug nuts$16.00
Bolts for fuel cell and battery mounting$15.00
PCV valve$10.00
COP screws x6$9.00
🧰 Remaining Components Subtotal: $5,521.00
💵 Grand Total: $7,688.64
its go time boys. i know a bunch of you have built some cars so i will ask for help along the way!
1975 dodge colt
2010 duratec 3.0l with a cheap 3586 or 3076 turbo ~450HP
jaguar 6hp26 6 speed trans again
9" rear with 4:10 and an ARB
maybe 26x10 R15 tires
i got most of the large dead parts chopped off now
plans are to build light but likely will weight a touch more than the factory car weight of around 2,100 to 2,200 lbs curb weight
would like to do the minimal cage to be 10.99 legal. plus it is a rust bucket now
i had chatbot make me a bumper sticker
So far the worst part is the drivers side back window only moves a small amount and then clunks to a stop
After the whores bath in the yard
the factory bumpers where very heavy and rusty.... they got scrapped
Look, I am not the smartest guy in the room but the dam seat belts don't even extend far enough for any human waist line!
that is tight in the pics. they extend no more
i am 6'2" so my grand plan is to lower the floor about 2" too
kinda vibing on a small bench seat too
Well shit
My excursion 3rd row seat out of my man truck is flawless in there
