THE NUCLEAR UNICORN
On our beam setup we added weld washers to the inside to add room for articulation so the shock ends doesn't bind. Not sure if you're having similar issues
I had planned to add weld washers to the inside of the tabs. After a ton of time and measurements over the weekend... I got it to cycle the entire 14" without any binding! I'm going to weld the washers on the outside now.
What is the limiting factor for your up travel is it the driver side beam hitting the bottom lip of the frame rail? Or U joint bind?
The limiting factor on my setup is the beams hitting the frame rail. My u-joints are heavily clearanced to accept maximum bump travel. This time around I may run RCV axles. Not too sure though. The bronco gets roughly around 18" of usable front wheel travel.
I plan on grinding out the u-joints as well any issues in the passed with the u-joints after material is removed from them?
Slowly cranking along on the unicorn rebuild. Shock mount-tabs are almost completely finished up. Once that’s finished up, I’ll slowly tie up the dash and mount a few of the accessories. At the same time I’ll be in the process of designing/building a tube core support that will be tied into the engine cage structure, that will be 100% removable with grill, headlights, etc… #builtnotbought #onemanshow #garagefab #americanmade #builtintheusa 🇺🇸#kingshocks #moruzziracemotors #toyotires #threatmotorsports #familyfunhaver #prelander #badlinesgoodtimes #cleandezert
Some Nuclear Unicorn updates.
Updates.. I ordered an OCHO Fab steering kit. And a (similar to this) 4L80 to Ford Reid case transmission from Maximum Transmission.
Some updates! Got the OhhCho fab steering cross member installed, mounted the power steering reservoir, picked up a PSC ported steering gear from my favorite dudes over at Desolate Motorsports, and grabbed a Howe steering cooler from Kartek.
Moving slowly, but surely..!
Very cool 🤘🏻
Correct me if I am mistaken but you have a 4.5” over beam?
If so, did you ever consider going up to ohhcho’s 6” over beam with the fabricated go fast hubs?
6” is pretty damn wide 😬
Very cool 🤘🏻
Yes, 4.5” over beams. And yes, I have considered the race beam kit at 4.5” over. It’s currently on the list of upgrades, just not at the moment.
IT MADE ME SOOOOOOOOOOOOO HAPPY TO SEE THIS NAME POP UP UNDER THE "WHAT'S NEW" TAB!!!!!!!!!!!!!
soooooooooooooo much looooooooooooovvvvvveeeeeeeeeeeeee for this thing all the way back from the DR days!!!!!!!
