The Grand Tracker (Retard TT)
Yeah i hate those, these wound up working out perfect. Now to get the damn fan shroud to work. I may try a high powered electric fan from a car/truck
I have a bunch of Spal fans sitting around that I’d love to trade for something cool.
Mostly 8-12” flavors
Spal Fans are the way, especially if space is a concern and budget isn't (they are a bit pricey as far as fans go) I have 'em on both my jeep and my c10 and never had issues with either overheating, I don't even have a shroud on the jeep either.
Taurus fan shroud aint going to work. Might be able to make a mark 8 fan work.
Spals were the first thing i was looking at but i dont feel they move the amount of air newer electric fans do on modern vehicles. Could be wrong.
Alright, where the fuck we at here…
Ah yeah, fuckin fan shroud issuse.
After multiple iterations of fan shroud repairs, i was about to ditch the mechanical fan but wanted to give it one more shot. Lots of plastic welding with chinee prastic sticker togethererer, hot melty wire chingadera, and a 1/2”x1/8” flat strap around the fan circle for support, think we got a chance. Also trimmed the shroud so the fan blades are 1/4-1/3 outside the shroud as ive read dis mo betta.
There is a nice foam edge around the whole perimeter to seal to the the radiator.
Jumped into fixing the driver side front body mount from there. Pretty damn sure i never updated on here about doing the passenger side but the jap crap metal was trying to allow the body mount into the cab. Anyhow, both sides got 1/4”x3” flat plate on bottom, 1/8”x1.5” on the front and 1/8”x.75” on back. Bad shit has gotta happen for that to come apart. Welds absolutely suuuuucked. Between a finger band sander, torch and scraper, grinder and brake clean, i could NOT get all the god damn undercoating off for smooth welds. Basically had to weld it, grind them and reweld.
Yes there is a gap on the one side, its due to the gay ass widening suzuki did. No i aint fixng it till its an issue
Once that was done, topped all the shocks and bumps off with nitrogen and checked the rear links for play. After 9 years and 40k miles, the lower link fk heims are finally showing play. Cant bitch about that. Ill throw new ones in after KOH.
Preran KOH desert course with no issues while taking course notes. Had a fun time racing, placed 3rd in class only to have it removed for bullshit reasons but we aint going down that road…
Left it pretty much untouched and a few weeks later, brought it out to the parker legacy race to be chase vehicle/crew mover. Smashed a bunch of whoops to and from camp to qualifying for fun and jumped the railroad crossing loaded down with everyone 🤣
Now got a trip comin up in April and she needs a little tlc. Prior to the legacy race, i did a quick check over and the rear lower link heims have finally got play in them after 7 years and 40k miles. They are just FK JMX14t-770’s (and L’s). Never expected them to last that long. Also need to brace the front radius arms (think they finally bent them selves back straight) and fix a few rattles.
Yup… as per usual, what should just be a couple things turns into a list [emoji1787].
Popped the hood and found the top rad mounts trying to tear from the core support. Im done fuckin with that. The core support moves too much compared to the frame. So added some bracing to the bottom and may add some from the engine brace that goes over the motor to the rad. Then everything moves with the frame
Next i found the muffler trying to create its own permanent verison of a cut out. It was cracking where it broke before, just behind the exit of the muffler. It was $30 bucks, i aint mad. Welded the crack back up and used some .060 sheet metal to it to brace it
If it dies again, time for something different
Wanted to add rear limit straps because im going quick enough now the rear is dropping out quickly on jumps or down hills at speed and slamming the rear shocks down. After cycling the rear end, figured out i can put the straps off the axle truss and bump stop mount. Didnt like all the weight yanking on just the one tab off the bump mount so i added another tab thats welded to the frame. Used a little .015 thick shock valve shim to give me some wiggle room
Found the pass side had very little room where i needed to mount on the truss. The holes they put in the truss are not equal space side to side so i filled one hole to give me enough steel for the strap. Gotta order the straps too
Da missing hole!
Tighted up the rf wheel bearing a bit.
Did a quick toe adjustment.
Dropped rear DS to grease the double cardan
Greased all zerks on steering, ball joints, drive shafts, rear link and rear panhard bar
Still need to:
Rear link heims
Put in limit straps when they show
Clean air filter
Fix the back door rattle
Check nitrogen pressures
Alright, shes pretty much done
Pulled the RR shock apart to remove the internal spacer so i can now use the same length limit straps. There is a long fucking winded explanation as to why this is due to the rear link design but lets just say a short panhard bar fucks this shit up
That spacer meant that whole shock came apart. Jimmy got a run down on shock rebuilds. Hes now a professional
He then proceeded to inspect my shit ass fabrication, piss poor welds and not bent but bent tubes. Was give a thumbs up after the pic
Fixed the weak rear door support when its closed. I mean… i guess its not really weak. Its more that 10 years of beating on this rig fatigued the metal a bit [emoji1787]. This will keep it from chattering
Added the limit straps with the help of the boy.
Changed 2 of the 4 rear lower link heims cause my dumbass ordered two rod ends that were NOT the 770 series so the misalignment spacers dont fit [emoji2357]. Ill have to run by foddrills this upcoming week i guess.
From there i moved on to rebuilding the turbo. Because thats what you do with a $150 turbo from amazon, you buy a quality $150 rebuild kit and put it in this china bomb! Why you ask? Specially when i have a brand new garrett 2860rs turbo on the shelf? Well thats simple… im fuckin retarded, duh.
Its in and works like it should. And as any normal person would due, i cranked the wastegate up some more. It only hits 8psi, might as well get back to 10psi for shits and explosions.
Checked all the shocks nitrogen levels and called it a day.
Just need two heim joints and oil the air filter
Finally checked the majove trail off my bucket list. Trip write up to come from the Bodj. Few teaser pics from the trip
Had an absolute blast. 50mph down the whoop section had me and the boy giggling like hell. Need to hit the balancing rock jump far faster. Still learning the limits of these beams and 3.0’s on the front
Damage report consisted of:
Fucked off passenger mirror. Driver ran out of talent and joshua tree said “fuck your mirror!”
Fan shround still ate its self but self clearanced for rest of the trip
Panhard bar emf joint needs tightened up
PS and Coolant bottles leak out the top when running whoops for miles
Rear axle housing is bending forward (not up). It was 1/2” toed in before the trip. Curious what its at now.
870 miles round trip. 250 of dirt. Ill take those little issues over that amount of miles and the ass kicking i gave the rig
Just went through your whole build thread. This thing is so rad! It works so good in the desert, smashing whoops, jumps and rescuing other TTB trucks.
You “go faster!”
Me “ I’m trying my best but I need to limit the sky wheelies…want to go by”
You “Yeah buddy”
Me….a little jealous this weird SUV making turbo noises blows by me and I don’t see it again until the regroup.
