84projectFORD
- Apr 1, 2022
Na, sure dont.
That came out nice! How deep is the front of your pan? I'm working on one for my 1UZ which should be the same as the 2UZ. I couldn't find much info on minimum oil depths or whatever so I went with ~2.64"Oil pan is done, plenty of added clearance
:O Well good to know in the future if I need more space I can get away with a much tighter pan. Since I'm swapping it in my Taco I can also move the engine up a bit which should help clear everything. I'm manual as well so I should be good with trans filling and thankfully I don't have a flex plate I need to access.Mine's a bit tighter, 1.75 to the block and using every bit of it for up travel. I was real surprised that even with the rear sump it has less capacity than stock, under 5 qts. You're also going to have to make a trans filler late and the flexplate bolts will be tough to get tight but possible.
