Oil pan is done, plenty of added clearance
Dunno, 8in or so after moving the sump? It's now 1.75 off the motor block. The motor itself is moved up about 2in at the axle as well for all the up travel clearance.How flat were you able to get it?
Stover nuts, my guy.Ah, the bolt should always be pointed down when possible so that if it loosens up gravity won't help it back out. Especially important near high vibration areas it will buy you a bit of time to tighten it back up if it is found before it falls out.
