TTBDORA
- Feb 3, 2024
Here’s the deal, acquired this ‘90 ranger….
“I’ll just finish this, redo that, get some parts…” nearly impossible to find time, between 1 weekend a month off & 4 boys.
So here we go!
*nothing is pulled off the truck, give me motivation* 2nd on call this weekend, might try to pull parts…
-6” over beams, pre ‘88 with I believe ‘96 spindles? 600$ hub to hub, with steering.
-Solo motorsports radius arms, 250$ with out pivots, 350$ if I get pivots off(partially welded on)
-Solo motorsports engine cage, frame plates are butchered, won’t include those, but can cut flush @ the plates. 475$ will give hardware
-FOA 2.5x14” coilovers, 475$ complete.
- ‘89-‘92 fenders 6”, core support inner lip, cut off & self tapper screws into core support. SICK. 175$
- Giant 55” lower links, RAW, a little rough, should clean up fairly decent! 450$
- Upper links, 3 link style, not sure of length, on the shorter side. 275$
-9” rear end, believe ruff stuff as well, gussets tab’d for 3 link, bump pads ETC.., will include 3rd member, spool & 4.88s, disc breaks, needs a seal. 1000$ unsure of the axles, it is 5x4.5 pattern..
-FOA 2.5x16” coilovers, completes 500$
-Some 22gal fuel cell 100$
Basically the truck ran & drove, needed finish welding amongst other things & redoing. Lost the trans, parked it.
Accepting offers on MOST parts!
Message on here or call/text.
859-691-7449, located in Murrieta CA 92562
Maybe willing to travel with parts, to meet up
Mostly between riverside/temecula(work route)
So here we go!
