Local Legend Project: Tur-BRO-yota
Late August 2016
Started rear cagework.
Main down tubes off b-pillar: 1.75x0.095 4130 with bent sleeves in them that went into the stubs out of the back of the cab.
Each side of the bent tube splice had 4 rosette welds.
Vertical tubes are 1.75x0.065" 4130
Horizontal shock mount tube is 1.75x0.120" 4130 chromoly
Straight diagonal tubes are 1.5x0.058" 4130
Aft tubes and upper bumper tube are 1.75x0.095" 4130
Tubes that extend from horizontal shock mount tube to mid b-pillar are 1.5x0.095" DOM. If (when, let's be realistic) I link the truck I'll beef that area up substantially.
I made all the tubes and cab close-out plates before starting any welding. I decided to TIG weld the entire back of the truck. It was a real pain in the ass--it was windy so I had to bump up my gas pressure to ridiculous levels even though I used a gas lens.
I fully welded all joints before covering them up with the next tube.
I didn't weld in the aft tubes yet because I didn't want to have to climb over them while welding the forward section and setting up shocks and bumps.
Early September 2016
Mounted Bilstein 2.65x17" 4 tube bypasses and Swayaway 2.0x3" bumps in the rear. I had these items in the shock pile in my master bedroom. My fiancé is a lucky girl.
Remember the machined upper shock mounts I was going to use with the Z-link? I cut those bitches in half and used them for the lower shock mounts.
I was going to use 1 u-bolt & 2 bolts per leaf spring pad.
I didn't like how that looked, so I eliminated the inboard U-bolts. And plated the bumpstop mounts.
Fitting the big formed dimple die gusset:
Because I was mating it from a 1.75 to 1.5" tube, I have to cut a wedge out of it. The pic sucks, but you can kinda see it.
It was going to rain, so I primed everything with self-etching primer. The painters I know spoke highly of the primer and said to scotchbrite the primed metal before paint. Historically, my track record with painting stuff is piss-poor.
This is my typical routine:
1: rust
2: expletives & blasphemy
3: WD40
4: Beer
5: Scotchbrite
6: Beer
7: Beer
Rear/bed cage weight: 90 lbs
27 feet of 1.5" tube
25 feet of 1.75" tube
3.5 feet of 2x3" rectangular structural tube
This includes the 2" x 3" x 1/8" rear frame closeout tube, 3/16" plating, and spare tire mount. It does NOT include the diagonal tubes that will connect to the shackle hanger. I'll add those tubes AFTER I verify that I like how the truck handles. If I want to change the shackle angle, I don't want to cut those tubes out. Said tubes will weigh an additional 9 lbs.
Here is the hour count:
Cagework: 38.5 hours
Tig welding cagework: 13.5 hours (this is included in the 38.5 hours for "cagework")
Deaver setup, shock, and bumpstop mounting: 49 hours
which includes: Setting pinion angle, Welding leaf spring pads, machining shock heim spacers, u-bolt eliminator bolt sleeves, and making bump strike pads: 8 hours
And welded in:
Mid-October 2016
New forward fiberglass mounts:
0.050 4130 sheet welded to a tube clamp made from 1.75"x.120W 4130. The pinch bolt tube is 3/4"x0.188W 4130. 3/8 bolts. I made a fixture to make those clamps. Weld the pinch tubes to the main clamp tube, then cut in half on the band saw. Hit them on the 20" disc sander to clean up the bandsaw cut.
All materials for the forward bedside mounts from the scrap bin.
Hours: 3.5
I left the ghetto rear 'glass mounts. I want to make some aluminum mounts later.
Got primer laid down just before the rain
Spare tire scheme
Rearend stats:
Toyota 8"
57.5" WMS to WMS (Me thinks)
4.56 gears
Limited slip (not sure of brand... gear guy thought TRD)
New high-quality bearings
New rear wheel cylinders and rear brake shoes
I traded the Toyota 8" 4.56/posi third member for a mill boring head. So no direct costs there.
It needed new bearings, so I took it to Bill Thomas Enterprises in San Berdoo.
(909) 888-7949
He does excellent work, and his shop is curious: No signage, located behind a self storage place, smells like cat piss--Place is crawling with pussy! Aaaaannnnnnnd, every gear set box that he's ever installed is thrown in a massive 12ft deep pile that takes up at least half the 2000sqft shop. Going to Bill Thomas Enterprises is a wonderful adventure!
Third member setup/tuneup with new bearings and seals: $450
New drum brake componentry: $83
Brake lines and fittings from G&J in Ontario: $102
Getting fucked and finding a perfectly good, complete E-locker 4.11 Taco rearend the NEXT GODDAMN DAY for $450---PRICELESS.
I swear to sweet baby Jesus. I saw it on Craigslist the very next day.
Total time in rearend tuneup and brake lines that are P-clamped to the back of the housing: 5 hours
G&J Aircraft & Competition
http://gandjaircraft.com/
Something to note, that axle eventually got sold and put on a red Toyota. The guy brought it to me to have the blingy shock mounts relocated, so I cut them off and made new mounts per his desired location. I held onto those mounts for a year or two before using them on my old tundra!
Moises bought it, came to the DMC meat fest and flogged the truck, and also came out to Yucaipa and thrashed around our local hills with @h0runner and me.
Early November 2016:
Got some used 33x10.50 BFG All Terrains on Outlaw II's for $100. Tires are a little dry rotted. I really want AR-23's, but I like these better than the black wheels with BFG Bajas. I think they look more period-specific.
In the right of the picture, you can see my fatTrevor sitting on my F350 tailgate. He's smoking and drinking and being super-helpful. At least he's not taking a leak in the yard like in the earlier post…
Late January 2017:
I had been driving the Turboyota a lot during December & January.
I'm going to outline the positives & negatives of that experience right now:
Positives:
1. It's very fast
2. Economy isn't terrible @ 17-18mpg
3. I smile when I drive it
Negatives:
1. No windshield wipers
2. No defrost
3. No heat
4. Deafeningly loud
a. Exhaust dumps under the cab
b. Resonance is terrible
c. B-pillar holes in floor still open
d. Bypasses clicking through the cage
5. The combination of exhaust dumping under the cab and open holes in the floor at lower B-pillar sucks exhaust into the cab if I roll the window down.
6. Cage x-bracing limits rear view mirror visibility
7. El Salvadorian window tinting is damn near impossible to see through at night.
8. 33's rub inner fenders on hard cornering
That experience prompted me to put the dash in.
Defrost duct was a bitch, but got it in
Outside vents will need duct mods to work
Time: 10 miserable hours
Battery mount pictures:
Late November 2016
There is still enough space between battery and cab for a 32 gallon fuel cell, but I'd have to move the battery aft if I use the JAZ jeepspeed cell.
The battery cable was nice and tidy, but I had the cut all the zip ties that held it to the seat tubes to close the rear holes in the floor.
The battery mount weighed around 10lbs, and I used about 1.5 feet of 1.25x0.065" 4130 tube to brace under the battery.
Battery weight: 49.5 lbs
Battery mount weight: 10 lbs
1.25" tube weight: 1.25 lbs
1/0 battery Cable weight: 6 lbs
Total time to move battery to the bed including fabricating battery box brace tubes, running cable, and temporarily mounting the locking selector switch between the seats:
5.5 hours
The Turboyota was getting a new home.
If you were paying close attention to the build timeline, you may have noticed that I didn't accomplish dick on the Turboyota from November 2016 until late January 2017.
From November to December of 2016 We fixed up and sold my fiancée's house and moved her into my house so we could live in sin.
Shortly thereafter, we purchased a 3 acre property that had a view and 2400sqft shop. (There's a house there too, but who gives a fuck about that...)
My time from November 2016 through March 2017 was almost completely consumed with fixing houses, moving, moving again, getting married, and then fixing/tuning up my house so I could sell it.
(I built and installed a long travel front end on BajaF150's MOBZA during that time, but that'll be a different thread)
The Turboyota was still getting daily driven, but I didn't work on it at all besides the fucking terrible, horrible, no-good, very bad dash install of late January 2017.
My new shop was awesome, but the electrical situation left much to be desired. On the left you can see the "panel" that was in the shop when I arrived. I installed the panel on the right and ran 220V outlets on dedicated circuits every 10 feet around the periphery of the shop. Thanks Dave!
Bought materials--Turboyota chilling in it's new yard:
Trenched in 350feet of 2/0 cable
Thanks Kyle, Matt, & Garrett!
Now the shop was usable.
Late March 2017
I cut more shit off the Turboyota...
Time to unbolt & cut off fenderwells and supports: 3 hours
Inner fenderwell & core support weight: 30lbs
Misc brackets & butyl from inside the cab: 10 lbs
Here's more from early April 2017.
Cut this bullshit off:
Started mocking up Sway-A-Way 2.5x10" shocks.
And Radflo 2.5x4" bumps. I think they're a little too big...
Cutting off stock droop stops & shock mounts: 1.5 hours
Mocking up shocks/bumps: 1.5 hours
Assembled SAW coilover weight: 60lbs/pair
Cost: $187/pair from Clist(I had the springs & coilover hardware)
Removed stock Tokiko shocks and steering stabilizer: 8lbs
Early April 2017:
Cutting radiator hoop horizontal:
One for my homies
Knuckle clearance by disc sander. Made little Easter egg bulkheads for the miter joints from 0.06" 4130 sheet
Made radiator hoop, doubler plates for behind new frame outriggers, and outriggers. Tigged radiator hoop. Migged outriggers and doubler plates. Started mocking up engine cage tubes:
Frame doubler plates: 0.125" 4130 plate
Frame outriggers: 2x3x0.125" structural tube
Radiator hoop verticals: 1.75x0.095" 4130
Radiator hoop horizontal: 1.75x0.120" 4130 with keystone quench
Time: 4 hours
Cost: Keystone & some knuckle skin
Early-to-mid April 2017:
Made inner engine cage tubes that connect to stubs through the firewall. 1.5x0.120" 4130
And started the outer tubes. 1.75x0.120" 4130.
How many rosette/plug welds do you guys usually do for a sleeved tube? I may be overdoing it... thoughts?
Welded the joints that would be covered by other tubes:
I made the radiator hoop nice and wide. I want to be able to fit a big (read: V8) radiator in the future without cutting out all the front cagework. I should have plenty of room...
Fully tig welded
Total time to get engine cagework tubes in and welded: 8.5 hours
Here are the hours, weights, and costs thus far.
Total hours: 421
(I think I have approximately 130 hours left--that will include front suspension, finish engine cage, interior tune-up)
Final Cage weight(173 ft of tube): 273lbs
Total Weight added: 665 lbs
Total Weight removed: 567 lbs
Net gain: 98 lbs
Cost to date: $6905-$955(sold items)= $5950 Total
Spent 1.5 hours mocking up the front shock mounts. Coils clear the arm and stock master cylinder.
I plan to make the upper shock mount catch both tubes and route around the master cylinder so it can be (somewhat) easy to replace if needed.
Also, I think I'll French a bent half-tube into the strut arm where the pitman arm sweeps across and makes contact. I'll plate the front and bottom of the strut arm to strengthen it.
Mocking up shock mounts
Template for the passenger side. There is minimal clearance to the intake manifold and throttle cable assembly.
Templates for the driver's side shock mount. The master cylinder will be fairly easy to remove.
I decided to do some PSC, (project scope creep) and clearance the firewall for 33's for now, and it'll clear 35's when I push the wheels forward.
I figure this is plenty of steering angle at full bump:
Fenders will require trimming when I make longer arms:
