Turboyota
- Apr 1, 2022
Late August 2016
Started rear cagework.
Main down tubes off b-pillar: 1.75x0.095 4130 with bent sleeves in them that went into the stubs out of the back of the cab.
Each side of the bent tube splice had 4 rosette welds.
Vertical tubes are 1.75x0.065" 4130
Horizontal shock mount tube is 1.75x0.120" 4130 chromoly
Straight diagonal tubes are 1.5x0.058" 4130
Aft tubes and upper bumper tube are 1.75x0.095" 4130
Tubes that extend from horizontal shock mount tube to mid b-pillar are 1.5x0.095" DOM. If (when, let's be realistic) I link the truck I'll beef that area up substantially.
I made all the tubes and cab close-out plates before starting any welding. I decided to TIG weld the entire back of the truck. It was a real pain in the ass--it was windy so I had to bump up my gas pressure to ridiculous levels even though I used a gas lens.
I fully welded all joints before covering them up with the next tube.
I didn't weld in the aft tubes yet because I didn't want to have to climb over them while welding the forward section and setting up shocks and bumps.
