Turboyota
- Apr 1, 2022
Mine are King. I don’t have much experience with fox IBPs.king or fox?
sounds like you need to be cruising the classifieds. how much travel?I was trying to have it all:
Raise ride height
Eliminate coil bind
Reduce static spring rate to soak up razor bumps
Increase bump spring rate by utilizing crossover nuts
I have no experience with 3.0 IBP other than Rouse. I'm not a fan as my truck is heavier and will end up with a much heavier wheel combo so greater damping will be needed and I've seen his shocks get pretty hot but maybe never fade? I also want to be able to tune the different zones easier than switching metering rods and shims. I'm way too lazy for that noise.
Do both with a torsion bar like the old Baldwin TTI have a set of both 3.0x10 and 3.0x12 triple bypass sitting on a shelf already, just need to make room on my truck for them.
8 tabs and 4 bolts … smashingI have a set of both 3.0x10 and 3.0x12 triple bypass sitting on a shelf already, just need to make room on my truck for them.
Let the record reflect that I suggested leaving everything and going to an IBP like I have on the Turboyota. My front end works great with a 3.0 IBP and our trucks are incredibly similar.
“IBP’s are expensive” is a somewhat valid response when you have 3.0 bypasses sitting on the shelf, I suppose.
He worked on my truck... He'll probably never work on beams again haha.Go more places, TTBs for everything! symmetry is overrated.
is that even possible? lolI definitely couldn't do stock beams, they are all over the place. I'd be afraid I'd end up more confused then Tommy's setup if I attempted it
Hah, do you even know BrianLess thinking and more "that works".
